Old 02-17-2013, 07:16 PM   #1
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Self-Install M&G Toad Braking System?
Has anyone self-installed installed the M&G Engineering Car Braking System?
I have a gas MH with hydraulic brakes, so I would need to install both the "air cylinder" in my Wrangler and the "Power Pack" in the back of the MH.
I'm not too worried about the power pack, but the air cylinder in the Jeep, with all of the adjustments could cause some frustration.
I am very mechanically inclined and think I could do it myself.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 02-17-2013, 08:03 PM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
No I haven't, but would be interested in how you make out and the advantages of this system.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 02-17-2013, 08:32 PM   #3
There's a place nearby that will install it but he wants over $600 for labor PLUS an additional $640 for the brake system PLUS an additional $195 for a breakaway system which I don't even want or need.
That comes to $1435 MORE than if I bought the unit myself straight from the factory.
I think I'll bite the bullet and install it myself.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 02-18-2013, 07:31 PM   #4
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
Lafayette , Louisiana
Good luck with the install Bob, I am anxious to know how it goes. I have an appointment to have my base plates installed on my toad and figured I would discuss braking with the installer then.
jrkeef is offline   Reply With Quote
Old 02-18-2013, 08:44 PM   #5
M & G Install
Thanks for the encouragement. I plan to order the system tomorrow after I have another conversation with Monty at M&G.
BTW, I did install the baseplate on our Wrangler by myself. Had to drill a couple of holes in the frame and cut some of the plastic rock guard to fit around it. I enjoyed doing it and it turned out great!
Will keep you posted.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 02-19-2013, 11:17 AM   #6
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
I am curious how different the Blue Ox Base Plates are from car to car. Once I have the base plates put on my current toad I guess you have to buy new ones if you change toads?
Old 02-19-2013, 12:07 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Check the laws for the state in which the toad is registered. You need to check the weight of the toad vs. the weight of the trailer that would require brakes. In Louisiana, where I live, trailers over 3000 pounds require brakes. Therefore, toads with a GVWR over 3000 pounds require supplemental brakes. Likewise, if a trailer requires a breakaway system, a toad with supplemental brakes requires a breakaway system, too.
I just went through this on my toad, which has a curb veight of 2600 pounds, but a GVWR or 3400 pounds and so needs a supplemental brake system. Because it has a supplemental brake system, it needs a breakaway switch, too.
Seems silly to have the breakaway switch; in order for the toad to break away, I would need to lose the towbar and two safety chains before the breakaway switch would even activate, so it's one step beyond triple redundancy. But that's the law, so what can I do?
Blue Ox and Roadmaster baseplates are model-specific. Anything installed BEHIND the front bumper has to be bought anew for any new toad. Anything mounted IN FRONT OF the bumper should be interchangeable from vehicle to vehicle.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-25-2013, 01:02 PM   #8
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
Marilyn and I dropped our LY at Premiere RV in Scott, LA this AM. They will repair/replace my hydraulic levelers this trip and order my Blue Ox Base Plates and a braking system for my toad. Phase II will be the Banks System install.
Old 02-25-2013, 05:55 PM   #9
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Since you mentioned your hydraulic levelers but not the cost of repair or replacement, probably same price for labor as either a repair or replacement means they have to come off the MH, would you mind giving the quoted prices and the final outcome. thanks.
Old 02-26-2013, 09:31 PM   #10
My M&G brake controller arrived a couple of days ago. I'm studying the install instructions and plan to do it myself. Will,keep you posted.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 02-27-2013, 07:38 PM   #11
jrkeef's Avatar
1994 30' Excella
2000 31' Land Yacht
I will let you know Dave. The shop is really back up and running behind. Fortunately I don't need it back until March 8th. My levelers work fine they just make noise going up and down. Hopefully it is fluid and grease.
Old 03-09-2013, 10:46 PM   #12
M&G Install
Let's get this thread back on track.
Today, I installed the toad portion of the M&G braking system with the help of my son who photographed it step by step. He went back to school this evening and will email me the photos later, which I will post soon.
It took a while, but went smoothly.
Overall, I am quite impressed with the engineering.
Stay tuned.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 03-10-2013, 08:33 AM   #13
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
How does it apply the brakes at breakaway?
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 03-10-2013, 11:29 AM   #14
M&G Breakaway
There is a separate breakaway kit option that M&G sells that needs to be installed if you choose to buy it.
It is comprised of a separate compressoir and air tank that gets installed under the hood of the toad that sends air to the M&G cylinder that I installed yesterday (in the case of a breakaway). I chose not to purchase it.
Thus far, we have towed our Wrangler over 20,000 miles with no toad brake and no breakaway, so I figure why go to the added installation hassle and expense.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
