Old 10-12-2015, 01:04 PM   #1
MJF
MJF's Avatar
2005 30' Land Yacht Gas 30
Oceanside , California
Seeking Driver Side Window Motor
need to find motor for 2005 landyacht drivers window
MJF is offline   Reply With Quote
Old 10-12-2015, 01:26 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you post a pic or two of the motor?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-20-2015, 03:30 PM   #3
2000 31' Excella
Ontario , Canada
Not to annoy you but what is wrong with the current motor? Found that the motor in my unit needed a better ground to the chassis. Is working fine now but who knows about tomorrow. If you find out the replacement motor part number, I would be interested.
Thanks and good luck.
woodytwo is offline   Reply With Quote
Old 10-21-2015, 06:28 AM   #4
GCinSC2's Avatar
If anybody has the common motor that these use, carefully examine it for any part numbers. It might be a carryover from an existing unit. Number might be cross referenced.
S/OS #001
Old 10-21-2015, 09:24 AM   #5
2000 31' Excella
Ontario , Canada
Getting at the window motor is a real pita. you need to remove a steel plate that covers the inside of door and the motor access area itself. there are steel rivits every 6 inches that must be drilled out. on mine I didn't find any part number.
when I was able to access the motor, I tried the window switch and low and behold the window went up and down. switch seems to be OK.
Old 10-21-2015, 09:47 AM   #6
GCinSC2's Avatar
Woody,
Still might learn from a picture who's motor they used. There is a GM window lift motor that fit a bazillion cars and trucks. Frequently called a pancake motor by some that have worked with it.
S/OS #001
Replacing Driver's side window assembly on Argosy. What rivets to get? nikmills Argosy Motorhomes 2 07-24-2014 07:55 AM
Driver side brake lights do not work 82 excella General Repair Forum 17 03-16-2012 03:40 PM
Supposed to be drip edge on Driver's Side? Johns5711 Land Yacht/Legacy Motorhomes 6 08-03-2011 05:03 PM
Power to Driver seat and side window humoso Land Yacht/Legacy Motorhomes 1 05-15-2005 07:20 AM
Driver's side wiper broken mcneon Airstream Motorhome Forums 27 04-24-2004 12:42 PM
