Old 07-10-2010, 07:52 AM   #15
Richmond Hill , Georgia
The sticker on the door says it's a '92. I thought it was a '94. Thanks for the reminder about insulation. Any recommendations on what kind? Could I use that in place of the "foam sandwich" technique? The new roof will be a rubber roof, so the final sub-roof has to be flush and smooth. Also strong enough so if I have to get on it, I have a strong support. The insulation I found when I removed the header above the drivers seat was R-13. Is that sufficient? Should I be thinking of the blown in kind that hardens a bit? Thanks for all your wonderful advice!
possummamma is offline   Reply With Quote
Old 07-11-2010, 01:06 AM   #16
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Roof insulation
What ever you do don't use the foam stuff that hardens! It drys and then can turn to dust when vibrations on road surface affect it. They make a rigid closed cell bubble/foil panel insulation that others have used in place of sidewall insulation in trailers that would probably work better for you sandwiched between the outer and inner plywood of your roof. Do a search here and you will likely find it under insulation. I forget the R-value but I am sure you will find it superior to R-13 bats and easier to install. I believe it can be glued to the plywood and would make for a stiffer roof. Hope this gives you more to consider. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-12-2010, 08:00 AM   #17
Thanks for the info, Biged. My head is now spinning with insulation questions. I did search the forums and what I found was info dated 2006. I like more updated info. I'll put a post on the insulation specific forum and see what comes up.
Update.....welder has given me a very reasonable price to remove, fab., weld, reinstall my new rood structure.
Old 07-12-2010, 04:56 PM   #18
richinny's Avatar
2011 34' Classic
when the welding is done, please have some fire extinguishers and water hose available. safety first :-)
Ricky
Old 07-23-2010, 08:13 AM   #19
Alimom4's Avatar
1990 36' Land Yacht
Kingston , Nova Scotia
Send a message via MSN to Alimom4
Originally Posted by richinny View Post
hey, it looks ready to install the second floor ;-)
**grin!**
Alimom4 is offline   Reply With Quote
Old 07-23-2010, 08:57 AM   #20
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
I referbed the complete inside of a '77 GMC 26 Palm Beach. Was impressed with the original sprayed in foam insulation. Also foamed a van back in 1980 and the thing not only was rattle free for the 7 years I owned it, but was like a styrofoam cooler! If I were to do the task you've started, definitely would find someone to spray foam on before closing the roof.
raveson is offline   Reply With Quote
Old 11-05-2010, 07:42 PM   #21
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
This thread had amazed me how far apart you had to take it, had to go looking but was wondering how the project was coming along?
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
land yacht, roof
Roof sealant removal and a leaky fridge vent Rob&Julie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-02-2010 05:47 PM
The addiction continues. . . . ddstech Interior Restoration Forum 4 06-26-2010 10:11 AM
Saga continues Dan S All Argosy Trailers 4 05-10-2007 08:54 PM
The scamming on my Argosy continues.... froggies Off Topic Forum 26 09-21-2006 11:38 AM
moneypit...the saga continues norbert Our Community 14 09-22-2003 07:33 PM
