Old 10-04-2010, 02:31 PM   #1
Green Bay , Wisconsin
Roof leaks in a 1999 Land Yacht
Is this a regular problem with a 1999 Airstream Land Yacht? The leak is in the front top of the roof where the seam comes together.
Carl
yaha64 is offline   Reply With Quote
Old 10-05-2010, 10:31 AM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I have a 1999 labeled 2000, it has had chalk applied to the seams, found a leak just over the drivers door where the roof meets the sidewall. PO had put in longer screws as some of the wood has deteriated. I chalked and replaced screws with intent to check from inside, but that is a big project as the headliner over the driver has to be removed along with curtain rail etc.
Also found marker lights leaked showing up as water in the courtesy lights over the dash. took them off caulked and replaced, design of marker lights can't stop driving rain.
Old 10-06-2010, 03:18 PM   #3
Leaks
Sounds like a regular problem with the P30 models ?
Don't know if I want to buy one now????
Carl
Old 10-11-2010, 12:09 AM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Land Yacht, Roof Leaks, Skylight Leak
I have some info on the Land Yacht, Flat Face, Clipper site that me help you.
http://www.airforums.com/forums/f313...aks-69566.html
Old 10-21-2010, 09:54 PM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Carl
if this thread stops you for a p3, you need to do more research on other brands as far as I can tell, all have joints, stress and leaks.
Old 11-17-2010, 10:18 AM   #6
Landshark II
1992 31' Legacy 30
Decatur , Michigan
Images: 18
Just bought a 1992 Legacy 31 ' great condition other than the roof leaks!!!! Easy fix!!!! Get on line and order some EtrnaBond Tape on ebay. Bought 3-4" rolls , about $60 per roll. Get your MH inside where it is clean dry and warm.. I got on top and removed all the caulking on the seams. Then I removed all the screws & rivits from the trim piece. Clean with lacquor thinner let dry. caulk under trim with 50 year silicone. Replace trim with stainless screws just a little wider but not longer. Let this dry for one day. Read directions on EternaBond tape and install... Real easy to do. once you see it go on, you will understand why it will never leak again...I had some left over, so I sealed around all vents, ect. Why pay some guy that works for a repair shop that doesn't know what he is doing.. Try it it is real easy...
Desikk is offline   Reply With Quote
Old 04-25-2015, 05:34 PM   #7
1996 35' Land Yacht Widebody
Fredericksburg , Virginia
1996airstream land yacht 33'
We purchased a 1996 Land Yacht which has developed a leaking roof. Anyone have a suggestion on best product to use .We are really new at this ,but are willing to try anything before there's no roof left!!!
eedeed is offline   Reply With Quote
Old 04-26-2015, 06:15 AM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
EEdeed you didn't say where the leak is at but if you have read the previous posts, you have read a couple of hints on fixes. If you continue searching you will see one member was so dedicated as to take off all the roof, never did see a completed outcome to that one. I found a leak under the caulking used to seal a vent, never would have known it was happening if I hadn't been in the process of replacing the bathroom vent, water can pool on roof and work past sealant.
Old 04-27-2015, 05:45 AM   #9
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Regardless of the make, any structure, be it a building or an RV, is subject to water leakage around any penetration or joint. Answer on an RV that is subject to sun exposure and flexing due to temperature extremes and movement down the road, is to inspect all joints and seams at least once a year and address any cracked or missing caulk.
Airstream12557 is offline   Reply With Quote
Old 05-05-2015, 07:34 PM   #10
2000 31' Excella
Ontario , Canada
Very very true. If someone says their trailer or m/h doesn't leak, it just means that they haven't found the problem yet.
woodytwo is offline   Reply With Quote
Old 05-05-2015, 08:30 PM   #11
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Tut tut you guys....Airstreams don't leak, they perspire.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 05-14-2015, 04:42 PM   #12
I repair, restore and renovate Airstreams in England, the roofs shouldn't leak? Any way of getting a picture of the problem? May just need a tighter pinching rivet or mastic or something, shouldn't leak! We've had originals from the 60s and they are sound! Maybe holes wer drilled at 4mm and had 3/2mm rivets in, a bodged job?
Tullerz is offline   Reply With Quote
1999 airstream land yacht roof leak yaha64 Roof 0 10-04-2010 01:01 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
