Old 04-14-2014, 02:46 PM   #1
1994 33' Land Yacht
bloomington , Illinois
rivets on transition piece.
Can screws be used in place if rivets? Is there anything to bite to? I thought I should use bigger rivets but it just looks like there is nothing to bit to
bertha 94 is offline   Reply With Quote
Old 04-14-2014, 02:50 PM   #2
A photo would help.
Screws become loose when they are subjected to vibration.
There are rivets for most any job imaginable.
Old 04-14-2014, 05:04 PM   #3
1994 33' Land Yacht
Here's one of the spots I am thinking of using screws.
Old 04-14-2014, 05:10 PM   #4
1994 33' Land Yacht
Sorry pic didn't take . It's a 94 airstream landyacht 33 ft motorhome . It's the rivets under the awning on the transition piece .what does the rivet bite on under the fiberglass outside?
Old 04-15-2014, 05:56 AM   #5
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
There is steel frame behind the the lines of rivets. What size are your rivets? These are the ones I purchased WESTWARD Blind Rivet,Button,1/4x 0.598 In,Pk 100 - Blind Rivets - 5NNZ5|5NNZ5 - Grainger Industrial Supply
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 04-16-2014, 02:29 PM   #6
1994 33' Land Yacht
Yes I bought the 1/4 rivets and repaired the side rivets .but the rivets on the topside .they look like there is nothing to go into .should there be metal on top too?
Old 04-16-2014, 09:28 PM   #7
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Yes, there should be metal to bite into. If not, then your steel rails are rusted out. You may need to seal the existing holes and drill new holes to secure the end cap.
92landyacht is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
roof rivets transition piece bertha 94 Land Yacht/Legacy Motorhomes 10 04-07-2014 10:46 AM
Can we replace floor piece by piece? tdturn2 Repairing/Replacing Floor &/or Frame 5 06-22-2009 08:54 PM
How to transition to PEX? OregonArgy Plumbing - Systems & Fixtures 12 05-05-2008 09:40 PM
