Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 09-07-2010, 04:35 PM   #1
1996 30' Land Yacht
Corvallis , Oregon
Reverse gear sometimes
Just bought a 1997 30' LandYacht on a Chevy chassis. When warm and put in reverse, nothing happens (sometimes). It is like it is in neutral. If I pull down slightly on the lever, it will go into reverse and slightly up you can hear the parking brake comming on. This implies to me that the tranny is OK and linkage isn't. Had some mechanics lub and oil everything and it got better, but still not right. I bought the service manual but cant find where to dig to find where the shifter motion is turned into a signal to the tranny and brake. Any ideas, pictures or diagrams would be useful.
davidullman is offline   Reply With Quote
Old 09-08-2010, 06:46 PM   #2
1992 36' Land Yacht
garden city , Michigan
Chevy P-30 chassis auto trans has a threaded rod that passes through the bracket on the trans for shifting. You just need to tighten the nuts up, with engine OFF, ign on, so you can see parking brake come on.
performancep is offline   Reply With Quote
30', chevy, land yacht
Brakes locking up in reverse GreatPumpkin Brakes & Brake Controllers 16 08-02-2012 01:30 PM
reverse light problems pablo Brakes & Brake Controllers 8 04-09-2008 08:28 AM
I need a reverse light housing!!! gretchen Lights - Interior & Exterior 1 05-21-2007 08:08 PM
Reverse lights till Electrical - Systems, Generators, Batteries & Solar 5 09-11-2004 04:29 AM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 08:00 AM
