Old 07-28-2013, 06:51 PM   #1
Johnsito's Avatar
1997 31' Land Yacht
Restoring bumpers on a '97 Land Yacht motorhome
I just bought this 1997 Land Yacht on Friday. It was sitting outside for a bit. The front and back bumpers are quite faded. Does anyone have any suggestions for restoring the color to the bumpers? Thanks!
Johnsito is offline   Reply With Quote
Old 07-28-2013, 08:57 PM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
I used a product by Wizard called Turbo Cut. It works good at removing oxidized fiberglas. Takes a lot of rubbing but I had good results. Rub out product till almost dry and work on small areas at a time.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 07-29-2013, 06:34 AM   #3
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Do a search on Red Max Pro. Basically you clean the surface using a none scratch pad and Barkeepers friend. Once dry you apply several coats of the Red Max Pro and you're done.
92landyacht is offline   Reply With Quote
Old 08-05-2013, 03:52 PM   #4
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
I would suggest NOT using Barkeeper's Friend, excellent cleaning product though it is...... you will get a matt finish.
Any automotive cutting compound will remove the faded appearance and restore the shine, which must be immediately preserved with a wax, preferably a high temp wax like Finish Kare FK1000P Hi-Temp Paste Wax with the big white shark on the tin. You might have to buy it online, but you'll never use another wax on your RV, car or boat if you get it. Any wax will preserve the shine though, but if you neglect to seal the surface with a wax, the paint will re-oxidize within weeks, and every time you remove an oxidized layer you reduce the thickness of your coachwork paint.
Punch is offline   Reply With Quote
Old 05-26-2014, 05:59 PM   #5
1997 31' Land Yacht
Mahone Bay , Nova Scotia
Looks just like ours! Actually, the PO had re painted just the bumpers front and rear, the sides of ours were very faded and mis-matched looking. We bought a box of 3 products for fiberglass - an oxidation remover, to be followed by a polish then the wax. We did this for the front and back of the motorhome and it worked very well. For the lower side skirting panels I used the oxidation remover then followed with a good wax (skipped the polish). The section I did looks wonderful, means we don't have to have the skirting painted.
Since the front and rear bumpers are fiberglass I would do the full 3 part treatment on them.
wheelygoode is offline   Reply With Quote
Old 05-29-2014, 09:03 AM   #6
Johnsito's Avatar
1997 31' Land Yacht
Thanks! Do you remember what brand you used?
Old 05-29-2014, 05:51 PM   #7
1997 31' Land Yacht
Yes, it is Meguires. There are 3 products, the oxidation remover, then a polish and then the wax. Blue bottles. We bought the three boxed together, but had to go back for more oxidation remover. We can get them at our local boat repair shop, also at NAPA.
Classic Airstream motorhome crazeevw Classic Motorhomes 60 12-12-2011 12:25 PM
1995 airstream land yacht motorhome motorhome no reserv eBay Watch Airstreams on eBay 0 08-31-2011 08:10 PM
Motorhome versus Trailer Member Search crzycpa Our Community 1 08-23-2011 12:30 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
