1995 35' Land Yacht Diesel
Ellisville
, Mississippi
Replace engine in 95 LandYacht Diesel
I just purchased a 95 Diesel Pusher 35 with a bad engine. I need advise on the best way to get the engine out and back in. The bad one was overheated due to a radiator leak and was run until it quit. A local shop removed the pan to find it full of metal fragments and said it was "fried".
You might get more information if you signed on the a forum covering that chassis or contacted the chassis manufacture to see if they ever published a service manual.
Good Luck
__________________ WBCCI 12156 AIR 3144 WACHUNG TAC NJ6 2004 Excursion 4x4 1991 34 ft. Excella +220,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
That is the ONLY way. You may be able to rig a derrick, use the lift ring near the thermostat and take the load, remove motor mounts and bell housing and drop it out. That is going to be a job, and an expensive one if you have metal in the pan.
