Old 11-28-2014, 08:29 AM   #1
2003 39' Land Yacht XL 330 hp w/2slides
Cincinnati , Ohio
Removing OTR Microwave
Any suggestion on removing and reinstalling a Convection OTR. I have removed the cabinet trim piece and the two screws on the wood panel above the MicroWave.
Cannot figure out how to remove the panel to excess the top of the Microwave to remove
the screws that hold it in place. HELP! 2003 Land Yacht XL 396
Thanks Ray #4983
rrstory is offline   Reply With Quote
Old 11-28-2014, 10:44 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Thanks Ray #4983
this is somewhat model dependent. Do you have an Interstate or a trailer or a motorhome. Year and model please.
Paula
Old 11-29-2014, 06:54 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Once the front trim panel is off the mw mine just pulls forward and out, first time when I removed mw to replace, it felt like it was screwed in, used long screwdriver as a pry bar lifted to loosen feet from 10 yrs of sitting. Yours is new and dif model so could be dif. these are custom mounts, specific to mw and rv.
Old 01-19-2016, 11:39 PM   #4
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
Most of the range top microwaves have different mounting brackets. In my 97 Land Yacht WB diesel, it came with a top of line micro/convection oven as it does not have the standard gas oven under the stove top. It was not working when I purchased the unit last April and no one would repair it. I think it was a Sanyo. Purchased a similar GE unit from Home Depo and it came with a different mounting bracket. Basically the bracket goes on the wall the 2 screws from the top hold it in place. That sounds easy but I did not have open cabinets over the Microwave. Had to remove the control panel (water, generator, indicator) and screw in by hand. Bought a small ratchet type screwdriver which was much easier than using an alan wrench. It took the whole weekend......but was worth it in the end!! Had to drill some new holes into the frame support also.
Mike1997 is offline   Reply With Quote
Removing the microwave in a 390 XL israndy Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 16 04-06-2016 07:07 AM
microwave compared to a convection microwave. Happycampers Airstream Motorhome Forums 6 02-23-2016 10:58 PM
Anybody replace their microwave to convection microwave in a 16 sport scamp 2005 and newer - Bambi all models 0 07-10-2014 04:34 AM
OTR: Main Hold Tank 911?! ibvegan Waste Systems, Tanks & Totes 7 12-01-2013 05:27 PM
removing microwave in Excella 1990 32' femuse Stoves, Ovens & Microwaves 0 03-07-2003 04:38 PM
