Old 06-20-2016, 10:01 AM   #1
1997 31' Land Yacht
Mahone Bay , Nova Scotia
Removing generator for service
Has anyone taken their generator out? Our genny is taller than the motorhome's clearance, so we are pondering the best way to gain space to get it out. We figured surely someone has done this!
We are getting fumes inside, so are guessing there is a leak in the muffler. We need to take the genny cover off to see, but have to drop it down even to do that. If we actually have to take it right out to work on it, we have two questions:
1. Is the electrical connection long enough to at least drop it?
2. What is the best way of jacking up the motorhome to get it out?
Thanks!
wheelygoode is offline   Reply With Quote
Old 11-10-2016, 08:57 PM   #2
1990 36' Land Yacht
Bradenton , Florida
Talking Remove Gen Set
Thanks!
To get more clearance, I would use lengths of 2X8 under the wheels. They can be stacked to get the necessary height (taper the ends and use long wood screws to make taller "stacks" more secure. You should be able to just elevate one side for the short time necessary to drop the gen set out. Use transmission jack or equivalent, to actually drop it down, as it should weight approx. 300#.
lonestranger is offline   Reply With Quote
Old 11-14-2016, 05:29 PM   #3
loreepeter's Avatar
2004 30' Land Yacht Gas 30
, OH
Suggest. Contact the manufacturer. Get the service manual. Generators are very heavy. Plus you do not want to cause additional problems. Fuel. Low voltage. High voltage. Exhaust. Proper torque when reinstalling. Plus you might want to do additional maintenance with gen removed.
gonagn
loreepeter is offline   Reply With Quote
Old 11-17-2016, 04:51 PM   #4
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
I would also consider parking on dirt & digging out the clearance.
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Old 11-18-2016, 03:23 PM   #5
1998 31' Land Yacht
AURORA , Colorado
I just did mine and did the same made some ramps and a floor jack came right out.
Big Denny is offline   Reply With Quote
Service A and Service B nesoutlook Sprinter and B-van Forum 17 12-14-2015 08:36 AM
Getting warranty service (or any service) at an Airstream dealer SeaLevel General Repair Forum 35 11-30-2015 08:01 AM
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 08:34 PM
Removing Onan Generator '74 Land Yacht ronsgto Generators & Solar Power 10 08-27-2012 03:05 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
