Old 12-19-2014, 12:42 PM   #1
2002 26' Land Yacht 26
plattsburgh , New York
remove batteries
I have a 2002 26' land yacht motorhome. to remove the batteries i need to remove an air intake unit that blocks the batteries. Can anyone help in telling me how to remove the air intake?
ibarbell is offline   Reply With Quote
Old 12-20-2014, 04:51 AM   #2
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
On my 2004 there is a clamp at about the firewall where the air intake horn makes a connection. Also, there is a bolt that has to be removed near the front of the air horn. This bolt holds a clamp that secures the air horn.
Sam
Airstream12557 is offline   Reply With Quote
Old 12-20-2014, 10:08 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
On mine there is a couple of screw clamps, don't remember any bolt, I do remember that I had to change the way the intake was installed as they put it in 90 degrees off and the drain hole was on the side, any rain water going in couldn't drain out, had to be sucked into the motor or evaporated.
Old 12-21-2014, 10:46 AM   #4
thanks
I will take a look at the way the "air horn" is attached today and see if I can remove it and the batteries. thanks for your advice
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
74' Excella, to remove wiring or not to remove? BaltiHimal Electrical - Systems, Generators, Batteries & Solar 3 05-30-2010 10:23 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
