Old 04-04-2013, 08:56 PM   #1
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Rear Shock Absorber Support
I was underneath the LY checking the brakes last week and just happened to notice that the support that attaches to the upper end of the right rear shock absorber was detached from the frame.
The support was still attached to the shock, but the rivets that held it to the frame were broken. How that happened is anybody's guess.
Maybe it was that 20 mile stretch of washboard dirt road I drove along the northern shore of Michigan's Upper Peninsula that did it.
I have no idea how long it was like that either. (The drive in the UP was a couple of years ago!)
Anyways, I took it in and they popped the rivet remnants out of the frame and bolted the support back in with some #1 grade bolts and it's as good as new.
I guess it pays to get on your back and get under there once in a while and check things out.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 04-04-2013, 11:17 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 55
Good find Bob.
Just because it is out of sight does not mean it won't break. The other side looked OK?
I try to crawl under my unit even on the road, anytime I have some free time. Then when you hear a noise you have a better idea what it might be.
I was lucky on our Cape Breton circle trip in 2009 when, on a routine stop, I spotted a broken bracket on my rear waste hose box. If I had not seen it, and traveled the rest of the day over that construction on the east side, I probably would have lost the box. A length of bailing wire did the job until we got to Sidney where I purchase a length of 1/2" alumium tubing and secured it better than OEM.
http://goo.gl/maps/KkHZc
Dave
"I guess it pays to get on your back and get under there once in a while and check things out.[/QUOTE]"
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 04-05-2013, 05:38 AM   #3
shock support
Thanks, Dave, the rig isn't getting any younger so I guess I'll have to be even more vigilant as time goes on. BTW, nice video clip.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 04-05-2013, 06:25 AM   #4
Images: 59
Bob, I think I'd take it back to the shop and have them use something better than Grade 1 hardware.
Old 04-05-2013, 07:39 AM   #5
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Same thing I was thinking. Grade 1 is the weakest. I'm just hoping that this is just a mistake and they really didn't install grade 1 bolts but installed grade 8 instead.
92landyacht is offline   Reply With Quote
