Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 10-15-2015, 01:28 PM   #1
kenajen's Avatar
2016 30' Classic
1972 23' Safari
2005 30' Land Yacht 30 SL
Georgetown , Texas
Rear Marker Light issue on 05 Land Yacht 30SL
I was trouble shooting a single red marker light over the rear window and found a corroded bulb and socket. I ordered a new light fixture from NAPA and then removed the old unit. The old one has 2 black wires, I guess that is due to the fiberglass body having no ground path. The new unit has only one wire and I guess that the fixture and screws are part of the ground path.
Now the problem: When testing the old socket with a volt/ohm meter I lost all of the red lights above the rear window and the three driving lights on the drivers side only. I checked the fuse and it is OK, and when removed all markers (yellow & red) and all tail lights go out, and come back when the fuse is replaced all but the ones mentioned earlier.
In my limited knowledge I would say that I blew a fuse or opened the circuit in the path of the lights that are not working. I have no DC at the wiring that I was working on at the defective socket. Could there be another fuse I'm missing? It reminds me of a Xmas light string.
Any help would be much appreciated!
Ken
kenajen is offline   Reply With Quote
Old 10-18-2015, 12:56 PM   #2
kenajen's Avatar
2016 30' Classic
1972 23' Safari
Georgetown , Texas
I found the gremlin!
After checking every bulb and socket of the clearance/marker lights that went out I dug into all manuals relating to the coach and chassis. What I found was the marker/clearance lights are on the left or right tail light fuse. This panel is under the hood. The marker/clearance light fuse is under the dash on the drivers side. Both fuses when pulled kill the markers and the tail lights. The fuse was a 5A mini under the hood. WOW did that drive me crazy!
1968 Overlander Running Light (Marker Light) Wiring Diagram or Routing Information Bunkroom Lights - Interior & Exterior 2 08-04-2018 01:16 PM
Tail Light and Marker light lens 68 TWind General Repair Forum 0 06-26-2014 11:34 AM
Rear Marker Light Installation... MDSilverado Lights - Interior & Exterior 7 10-23-2010 07:56 AM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
