Old 06-16-2016, 09:05 AM   #1
Albuquerque , New Mexico
Rear Aircon only works on Genset?
Hello All,
Our 1997 LY30 has two ACs but the rear works on genset only and not shore power. The front works on both. A clue: When I start the genset with both ACs on, The real turns on as soon as the genset does. The front turns on after 30 sec. or so after starting. Any Ideas? Thanks
kdullea is offline   Reply With Quote
Old 06-16-2016, 02:02 PM   #2
I think I got my answer, 30A shore power can only power 1 ac at a time. I need to get a switch between the two.
Old 06-16-2016, 03:20 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The time delay is most likely designed in so the starting current of the 2 units does not happen at the same time.
Each AC should have a time delay built in to allow equalization of pressures within the unit to accrue if there is a power interruption. Commonly 2 or 3 minutes. Without that time delay you can slug the compressor and that is not good.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 06-16-2016, 03:30 PM   #4
Gainesville , Florida
I think your ac is operating properly.
Old 06-16-2016, 05:16 PM   #5
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
You have a switch. Its in the cabinet above the stove.
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Old 06-16-2016, 07:38 PM   #6
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
You should never start or stop the generator with a load hard on the generator and the transfer switch.
Garry
Old 06-16-2016, 10:36 PM   #7
Registered User
1996 30' Land Yacht
Benson , Arizona
Confirmed that our 96 LY30 switch is above the stove as well. Looks like a light switch in the cupboard.
pago cruiser is offline   Reply With Quote
Old 06-18-2016, 07:22 AM   #8
Carhampton , Somerset
Hello All,
On my unit there is a switch over the cooker/extractor fan that switches the front from AC off and engages the rear AC in the bedroom
Jackhyde is offline   Reply With Quote
Old 06-20-2016, 07:52 AM   #9
I found it! Thank you!
Next question: Is there a switch between Shore cable and ant? TV did not see the cable channels after doing cable search.
Old 06-20-2016, 09:20 AM   #10
HowieE's Avatar
Images: 12
Shore power has no influence on the TV input other than lighting it up.
There are a couple of things that may be effecting your reception of cable.
Some systems have a Selector Box, a separate control that governs which signal if feed to the TV.
Newer smart TV have several inputs options on the back of the TV. If that is the case you have to select the input via the TV control before scanning.
2004 Excursion 4x4
Old 06-20-2016, 09:50 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Look for a VERY small push button on the plate where the television coax connects. Red light on is TV. Red light off is cable/satellite.
Old 06-20-2016, 01:02 PM   #12
garypk's Avatar
1998 31' Land Yacht
It's camping. Throw out the tv.(LOL)
1960 Aircon Help please amysemmens Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-24-2014 04:04 PM
Rear AC receptacle only works on shore power paullovern Sprinter and B-van Forum 17 09-02-2014 11:31 AM
Aircon and shipping oet Shipping & Export/Import 1 03-14-2011 02:23 AM
Can I leave aircon running all day and night? leong1 Furnaces, Heaters, Fireplaces & Air Conditioning 26 07-07-2009 03:34 PM
Aircon and heater thermostat wiring ianrjam Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-04-2007 10:48 AM
