Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 07-20-2017, 11:41 PM   #1
idahojim's Avatar
2005 26' Land Yacht Gas 26
Hayden , Idaho
Rear Airbags on Land Yacht 26 - Nice Upgrade
I mentioned to our mechanic that we had some sway during strong winds and asked him to install sway bars in the rear. He suggested and then installed airbags instead. He then ran the valves to rear of the rig for easy filling, etc. It's made a nice difference in the overall ride. I'm wondering why Airstream didn't do this in the first place?
https://photos.app.goo.gl/E399O26dr8fO97xI2
idahojim is offline   Reply With Quote
Old 07-21-2017, 03:33 AM   #2
Sag Harbor , New York
FYI Jim your link only opens a blanked-out license plate, from what I can make out. I don't see any left or right arrows to scroll to more photos.
Peter
Old 07-21-2017, 11:00 AM   #3
2004 26' Land Yacht Gas 26
Thibodaux , Louisiana
Airbags? I have a 26 also, do not have much trouble with sway but if it help the ride that would be nice. Do you have a link to the manufacture ?
latenite23 is offline   Reply With Quote
Old 07-21-2017, 02:12 PM   #4
idahojim's Avatar
Hayden , Idaho
Peter
There's little valves on left and right. I set them at about 60lbs. I'll find out who makes them. For some reason when I share photos via link with Google photos the link does not pull in the picture.
Old 07-21-2017, 02:14 PM   #5
idahojim's Avatar
Hayden , Idaho
Originally Posted by idahojim View Post
there's little valves on left and right. I set them at about 60lbs. I'll find out who makes them. For some reason when i share photos via link with google photos the link does not pull in the picture.
Old 07-21-2017, 11:10 PM   #6
idahojim's Avatar
Hayden , Idaho
I think this is it based on the sticker. http://www.truckspring.com/products/...ear__2147.aspx
Old 07-23-2017, 04:58 PM   #7
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
Airstream did put airbags on the rear. I have 4, two rear, two front. Only problem with this is not having a manual dump switch to help when leveling. Discovered that use of the hydrolic levelers makes them dump automatically but will refill if key is left in on position.
Mike1997 is offline   Reply With Quote
Old 07-24-2017, 05:22 AM   #8
Upgrade
The Firestone Kit in the thread looks like you do set it and forget it? Does it require any pumps etc... to be installed?
Old 07-25-2017, 07:09 AM   #9
idahojim's Avatar
Hayden , Idaho
Mine has 2 valves our mechanic installed on the back of the rig (one on each side of the license plate) so I can adjust the rear based on weight load.
Old 09-29-2017, 06:30 AM   #10
Front Sway Bar
Did your mechanic recommend anything for the front as in a sway bar?
Old 09-29-2017, 06:46 AM   #11
Missing Front Airbags
I just looked under my front, I have the air lines but no airbags?
Old 09-30-2017, 09:19 PM   #12
Mike1997's Avatar
Images: 14
Their is a company in NC that makes replacement air bags and springs to retrofit. Most of their retrofit applications were developed for older Lincolns with deflated bags and Land Rovers. Most recently they have created an aftermarket application for pickups specifically towing 5th wheels.
Don't have their info handy but can respond directly to those in need of their contact info.
Old 10-01-2017, 09:28 AM   #13
idahojim's Avatar
Hayden , Idaho
We just got back from a trip to Calif and Bend Oregon. Strong winds and she drove great with new air bags in back. I checked under the front and we have a Bilstein steering stabilizer and a big sway bar installed. Not sure if this was stock or installed by original owner. We keep air bags in front at 80 and rear at 60.
Old 10-01-2017, 03:27 PM   #14
I did some checking, I think the PO installed the super steer springs which eliminated the need for the front airbags. I do have a front facing single shock with a spring on it. I assume that is some type of stabilizer. I use the Rig for tailgating at LSU and it is pretty stable at 70 mph cruise. But do want to add the rear bags, I fee that may be a nice upgrade.
Old 10-01-2017, 04:30 PM   #15
What was the cost to have them installed
Old 11-05-2017, 10:01 PM   #16
Newburgh , Alabama
HWH just came out with an air adjusted ride that compensates to a level ride while traveling. It would adjust the coach say your traveling down a road with a crown of 5% it would adjust the coach so that it would be more level. I Know it's just money but someone has to think this stuff up!
jperrey is offline   Reply With Quote
Old 12-26-2017, 07:45 PM   #17
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
I just took delivery of some suspension additions. The PO added Super Steer bell cranks and a panhard rod in back. I saw good review of the SumoSpings that replace the bump stops and replacing the non-working front airbags.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
TerraYacht is offline   Reply With Quote
To replace rear airbags on Classic 350 w/Tag Axle boones Airstream Motorhome Forums 6 11-24-2020 10:34 PM
Replacing front airbags on my '92 Land Yacht 92landyacht Land Yacht/Legacy Motorhomes 15 06-27-2013 09:48 PM
1965 Safari Airstream Land Yacht Travel Trailer 22 Ft Nice Moab Utah Nice NR eBay Watch Airstreams on eBay 0 07-14-2012 04:20 PM
Rear airbags needed for my 1988 345 motorhome Mr. D Mechanics Corner - Engines, Transmission & More... 2 04-03-2006 03:05 PM
When should the rear airbags be replaced? AccessMaster Airstream Motorhome Forums 41 09-26-2003 02:01 PM
