Old 01-01-2011, 11:06 AM   #1
2004 30' Land Yacht 30 SL
Sarasota , Florida
Rattling driver's door
Looking for suggestions on how to fix a rattling driver door on an '04 Land Yacht motorhome. The door itself appears to fit correctly in the frame. However, the outer part of the door (part holding the window glass) does not seem to be attached tightly to the inner part, resulting in annoying rattling when driving. Any ideas? Thanks. George
geotraveler is offline   Reply With Quote
Old 01-01-2011, 11:41 AM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
A few well placed screws might help, I found mine seemed to be connected with a minimum amount. RV place has the plastic caps for screws that will match the plastic panel.
Old 01-01-2011, 11:59 AM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
When I bought mine it had a bad rattle, hard to find. If you remove the inside door panel, mine had door bracing that wasn't glued properly. I siliconed that and anything else that would support the exterior skin.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 04:11 PM
Bathroom sliding door polarlyse General Interior Topics 2 05-21-2011 07:54 PM
Moho generater door Smartstream Classic Motorhomes 23 05-16-2011 06:02 PM
Door lock issues carlvs Doors & Locks 4 05-09-2011 07:57 AM
