Old 04-08-2012, 09:20 PM   #1
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Question: TV Audio through Radio Speakers
The Owners Manual, Parts Manual and the Specification Sheets of the 1998 through 2005 Land Yacht 30ís all make reference to a ďswitch" to make the TV sound go through the 4 radio speakers.
Can anyone tell me where that switch is located and how it works?
Hope everyone had a GREAT Easter!
RAG is offline   Reply With Quote
Old 04-08-2012, 09:36 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
On my Clipper, the switch is located on the dash with the group of 8 HELLA rocker switches. The TV sound has to go thru the Sony radio power amplifier as the TV itself is not equipped to drive the speakers. On my Clipper, the amplifier is only 2 channel, and is located on the back side of the oak center dash console which has to be pulled out for access.
The wiring was already in place to the upper right cabinet on my Clipper, but I had to find it as it had been pushed back and hidden behind the upper side panel.
This is general information only, as yours will be different as the TV is dash mounted on yours. You will just have to look for the location of the amplifier.
The TV's are factory wired so that the TV goes off with the ignition on. If yours has been modified, the wiring may no longer be factory specs.
Dave
Originally Posted by RAG View Post
The Owners Manual, Parts Manual and the Specification Sheets of the 1998 through 2005 Land Yacht 30’s all make reference to a “switch" to make the TV sound go through the 4 radio speakers.
Old 04-08-2012, 09:57 PM   #3
RAG
RAG's Avatar
Dave
Hi Dave,
The Clippers must be set up differently; I canít find a switch on my dash. The TV itself isnít up front on the í04ís; itís behind the dinette.
Thanks for the responseÖ.
Old 04-08-2012, 10:11 PM   #4
masseyfarm's Avatar
Images: 56
Was that factory installed?
I guess yours is too new for me. The ones I have seen had the TV in the center dash area.
Dave
Hi Dave,
Old 04-08-2012, 10:35 PM   #5
RAG
RAG's Avatar
Dave
From the factory, the 2004 and 2005 Land Yacht 30's have the TV's over the dinettes. The dash area was changed to a double-door smoke glass cabinet. I like to think of it as an interesting place to put a self-service bar.
Old 04-09-2012, 02:08 AM   #6
richinny's Avatar
2011 34' Classic
check the radio manual. the new units (sony) have a menu to select different inputs. on mine ?(2011)i select aux for the tv sound.
Ricky
Old 04-09-2012, 04:49 AM   #7
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
RAG, on my 2004 LY gas, the only TV that plays (played) through the remote speakers was the small TV in the bedroom. The switch is over the head of the bed. The TV, as supplied, was an analog TV and had no built in speakers. I removed the small TV and use it as a place to put an electric cube heater for the cool nights. We don't watch TV in bed, and the TV would have needed a convertor box or cable signal to operate, so we removed it. The dash radio also plays through the speakers over the head of the bed.
Sam
Airstream12557 is offline   Reply With Quote
Old 04-09-2012, 08:03 AM   #8
RAG
RAG's Avatar
I donít see how this ďswitchĒ, (Part# 510929-06 Switch ~ TV audio through sound system), that Iím trying to locate would have anything to do with the dash radio, as the ignition would have to be left on in order for the radio to work. But, I could be wrong.
Sam, on our í04 LY, the bedroom TV plays sound through the single speaker in the center of the overhead above the bed. The 2 speakers on the sides of the overhead are the dash radio speakers that somehow, along with the 2 radio speakers in the driverís area, are switched to become audio for the TVís. As for the TV signal, we donít use the antenna for reception; the 2 sets are there exclusively for DVD movies and possibly cable TV at a campground.
Why is this "mystery switch" important? When you put a CD into my DVD player and turn the TV or TVs on, the music plays through the TV speakers. Playing the music throughout the coach on the 4 stereo speakers, should just be a much better sound.
Old 04-09-2012, 12:13 PM   #9
masseyfarm's Avatar
Images: 56
Again, yours may be different. On my Clipper, the radio, TV, etc. is wired to the house battery circuit and not the ignition.
When I look at your model dash, it looks like a TV to me.
I did not know they moved them from the dash.
Dave
Old 04-09-2012, 02:26 PM   #10
RAG
RAG's Avatar
Dave
Yep, looks like a real nice flat-panel TV, but it's not. If you look very closely, you can see it's 2 dark smoke glass doors with 4 round glass-mount hinges and 2 door pulls.
Interesting what you said about your radio being wired to the house batteries. Mine requires the house batteries to be turned on, but it also needs the key in the ignition and the switch turned to "run" or "accessories". Kinda defeats the purpose of wiring to the house batteries, doesn't it?
Old 04-10-2012, 04:52 AM   #11
RAG, first, my radio, and I assume it is original, works directly off the battery. The ignition key does not have to be on or in accessories. How about that! I also removed the original TV in the living area and replaced it with a similar size digital. I saw no connection from the TV sound system to the four speaker radio sound system.
Old 04-10-2012, 05:16 AM   #12
RAG
RAG's Avatar
Sam, when you say, "works directly off the battery", do you mean the chassis battery or the coach batteries? Mine works off the coach, but the ignition needs to be on. If I'm driving down the road and my wife turns off the coach batteries, the radio goes off, yet if parked, ignition off and coach batteries on, the radio won't function.
And there's still this "switch" that's supposed to be somewhere. I called Airstream this morning and left a message; hopefully, they'll return the call.
Old 04-10-2012, 05:33 AM   #13
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
Don't know if it's the switch you're looking for, but on our 05 LY there is a well hidden (mystery) switch & turn knob in the cupboard above the TV. It's behind the plug on the top shelf. We've never figured out what it's for. But, a speaker switch & volume control knob make more sense than any of the other ideas we've had.
Schools Out is offline   Reply With Quote
Old 04-10-2012, 08:07 AM   #14
masseyfarm's Avatar
Images: 56
Sounds like the radio, and the amplifier for speakers, are wired to different battery circuits??
Dave
Sewer question - 1968 Airstream goswick Plumbing - Systems & Fixtures 8 04-11-2012 08:37 PM
Bedroom TV Removal / Adjustment DMT Audio, Video & TV 0 04-08-2012 06:49 AM
12V feed for TV rbr Audio, Video & TV 1 04-07-2012 07:54 PM
Question: How many HP?? Gocart General Repair Forum 2 04-07-2012 03:23 PM
Tow Question 10drum Towing, Tow Vehicles & Hitches 2 04-05-2012 08:46 PM
