Old 06-24-2018, 07:29 AM   #1
Tim Eagle
tmeagle1's Avatar
1995 31' Land Yacht
Sandusky , Michigan
Send a message via MSN to tmeagle1
Power Step
My power step is stuck...extended. It works most times. I hear it clicking when the switch is on and I open and close the door, but nothing happens...the step stays extended. I do have my chassis battery disconnected and this may be the problem, it's done this before when the chassis battery was connected. Any suggestions? 1995 Airstream Land Yacht.
Tim Eagle
Dark Nest Travels
Dark Nest Travels: youTube (content shortly getting there)
Dark Nest Travels : Blog (if you'd rather read our ramblings and history)
tmeagle1 is offline   Reply With Quote
Old 06-28-2018, 06:57 AM   #2
idahojim's Avatar
2005 26' Land Yacht Gas 26
Hayden , Idaho
Ours had this issue and it turned out to be a worn out gear. Our RV mechanic fixed it as the Quickee step has replaceable parts so about an hour labor and it's back working fine.
idahojim is offline   Reply With Quote
Old 06-28-2018, 10:40 AM   #3
Tim Eagle
tmeagle1's Avatar
1995 31' Land Yacht
Sandusky , Michigan
Thanks. I hope that it's a battery issue. I will keep you posted.
Sincerely,
Tim Eagle
Dark Nest Travels
Sent from my LG-K540 using Airstream Forums mobile app
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 10:28 AM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 01:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
