Old 11-29-2013, 02:30 PM   #1
2000 33' Land Yacht
San Antonio , Texas
Power jack reservoir
can onyone tell me where the power jack reservoir is on my 2000 land yatch
jraglow is offline   Reply With Quote
Old 11-29-2013, 04:29 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
reservoir? I have 3 power jacks - none have a 'reservoir' do you mean as in Hydrolauic fluid reservoir? Mine all have grease for the gears.
Silver Hawk is offline   Reply With Quote
Old 11-29-2013, 05:48 PM   #3
2000 31' Excella
Ontario , Canada
Hi . I asume that you are talking about the resevoir tank for the 4 power levelers. On my 2005, the tank is located in front of the engine on the driver's side. It is about 12 to 15 inches high and 7 to 8 in in diameter.
I do recall reading somewhere that the tank in the older models was located behind the rear wheels on the driver's side. be patient. I'm sure someone who has your model year will have the correct answer in a day or two. This is a busy weekend for alot of folks.
Happy Thanksgiving.
woodytwo is offline   Reply With Quote
Old 11-30-2013, 08:26 AM   #4
2000 33' Land Yacht
San Antonio , Texas
thanks, yes I mean the hydrolic fluid reservoir.. Still looking for it.
Old 11-30-2013, 08:35 AM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Woodytwo described my 2000 31ft LY location. If I was looking for it without knowing it, I would assume it was a large pump and reservoir combination taking up about 1 cu ft of space and should be relatively easy to get to. Mine has a 1 inch ss cap nut near the top side of the unit to add fluid.
Old 11-30-2013, 09:29 AM   #6
2000 33' Land Yacht
San Antonio , Texas
Thanks, saw what you described but didn't remember adding fluis there, it's been several years. I prreciated the help
Old 12-01-2013, 04:23 AM   #7
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Be sure to read the manual and/or information on the pump to see what kind of fluid is needed in the system.
Sam
Airstream12557 is offline   Reply With Quote
Old 12-01-2013, 10:50 AM   #8
1988 32' Excella
Robbinsville , New Jersey
Also check the manual for what position the jacks should be in, my guess the jacks should be all the way up when checking fluid. If the jacks are in the wrong position you can severely overfill the reservoir by filling to the fill line.
Old 12-01-2013, 06:37 PM   #9
2000 33' Land Yacht
San Antonio , Texas
Thanks to all.
