Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 10-17-2009, 11:33 AM   #1
Profile:  milverton , Ontario
Power Gear Levellers
I have purchased a 99 Landyacht 33 ft. It is eguiped with the power gear levelling system. When I used the unit in warm weather everything seemed fine. but now that temps are down to freezing I noticed the jacks down light comes on during hard acceleration and goes out again at normaloperation while driving. My question is should I top off the fluid while it remains this cold or should it be left for warmer temps as the fluid wil expand when it is warmer? Hate to fill it for cold and have it overfull when warmer. Thanks for any help.
roesy is offline   Reply With Quote
Old 10-26-2009, 06:20 AM   #2
harold1946's Avatar
Profile:  Surprise , Arizona
I would go ahead and fill it. Don't think there would be enough expansion to worry about.
harold1946 is offline   Reply With Quote
Old 10-26-2009, 08:48 AM   #3
DaveFL's Avatar
Profile:  2000 Land Yacht 30(31') , Inverness, between the Withlachochee River and the Gulf of Mexico, Fl
Check the pads and see if you can determine which one is leaking, mine was from the rear drivers side, fixed by adding transmission seal, when leak stopped changed oil, resevoir held about a gallon.
DaveFL is online now   Reply With Quote
Old 10-26-2009, 05:05 PM   #4
Thanks for the posts. I will top it up and keep an eye on it to see if I can find a leak.
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 12:52 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 09:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 09:23 AM
gear ratios RVNUTTY Tow Vehicles 11 09-04-2004 04:38 PM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 09:00 AM
