Old 09-06-2015, 11:27 AM   #1
RAG
RAG's Avatar
2004 30' Land Yacht Gas 30
Canadensis , Pennsylvania
Power Gear "Control Box" Location?
Hi Folks,
Might anyone know where Airstream located the Control Box for the Power Gear Leveling Jacks (2000-2005). According to available information, Land Yachts, beginning with 2000, used a remote located Control Box model #500457 (1st photo) and a dash mounted Touch Pad model #500456 (2nd photo). I have no idea where this control box is located but, it contains (4) 3 amp fuses, one of which may be the reason my front jacks do not work.
I believe the Control Box might have a cover over it, but again, I don't know what it looks like.
Any and all help is always appreciated.
Regards and safe travel,
Randy
ID:	247370   Click image for larger version
RAG is offline   Reply With Quote
Old 09-06-2015, 06:34 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
On my 96 CLIPPER, the control box is on the ceiling of the basement, forward of the fresh water tank, inside the frame rails. Yes there are a number of fuses in that module.
You might locate the area of the solenoid box and make sure all the wires are secure to each solenoid. (This is probably located near your hydraulic oil reservoir?)
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 09-07-2015, 05:59 AM   #3
RAG
RAG's Avatar
Dave
Thanks for the response, Dave......
Is your dash mounted touch pad the exact one I have pictured in my original post?
Thanks again,
Randy
Old 09-07-2015, 06:02 AM   #4
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
One control panel was on the high side of the fender well at the left side (inside the cab).
Airstream12557 is offline   Reply With Quote
Old 09-07-2015, 06:32 AM   #5
masseyfarm's Avatar
Images: 56
The Dash control touch pad plate on the 96 CLIPPER is pn 500535. It is similar, but the view is reversed from what you have shown. The information and touch buttons are condensed into a smaller pad surface than yours. My plate measures 5 x 3 3/4"
Dave
Thanks again,
Randy
Old 09-07-2015, 10:29 AM   #6
jackson center , Ohio
Control box
[try looking in the RS exterior front compartment
QUOTE=RAG;1680123]Hi Folks,
Randy[/QUOTE]
Schu is offline   Reply With Quote
Old 09-07-2015, 10:57 AM   #7
Rockin' my Land Yacht 26
steveQ's Avatar
2005 26' Land Yacht Gas 26
Fall City , Washington
In my 26' Land Yacht it is behind the "Center Console Shelf". Wasn't looking for it, but found it as I removed the console by removing the screws that hold the doors in place. Once those where out, the entire box came out and voila, ...there it is, mounted upside down on a thin metal bracket.
Good luck!
Steve A.
Proud owner of Glinda, a 26' Airstream Land Yacht
http://www.steveqanderson.com
steveQ is offline   Reply With Quote
Old 09-11-2015, 05:52 PM   #8
normandgrace's Avatar
2005 33' Land Yacht Gas 33
pembroke pines , Florida
Shu has it right. Curbside front compartment behind entry door. Top of the compartment in the far end. Save a ton of money and look for parts on eBay or Amazon. Just replaced my keypad and saves $300 over what the repair tech would have charged me
normandgrace is offline   Reply With Quote
Old 09-12-2015, 11:47 AM   #9
RAG
RAG's Avatar
You called it! That's exactly where it was, Thanks!
Harder to reach than a more generous designer would have allowed, but not out of the ordinary for most RVs.
Below is a proper layout of the 4 fuses, as the diagram in the manual didn't match-up to what I found.
Safe travel and my thanks to all,
Randy
Old 09-15-2015, 12:37 PM   #10
RAG
RAG's Avatar
Power Gear Front Jacks
Well, the fuse in the remote located "control box" which operates the front jacks, is good (damn!); even swapped it out with one that's known to be good, in order to be sure. The rear right and left jacks, both together and independently, work properly and the fluid level is, and has been, at the proper level. The motor is working when the front jacks button on the dash pad is pressed, as it makes that "motor sound".
Our Land Yacht 30, "Christine", has had a habit of rather unusual "fits" from time to time, e.g. the radio comes on and off at various intervals without any buttons being pressed, so therein lies her name. Those of you familiar with Stephen King's "Christine" (book or movie), will understand. Wouldn't be surprise if everything worked fine tomorrow.... but I doubt it.
Not sure where to go from here, or maybe it's to the lumberyard for a few leveling planks for the front tires. Not my first choice, but are there any others, short of leaving her at the mercy of a "Camping World" type service shop?
As always, any and all help or suggestions are greatly appreciated.
Regards and safe travel to all,
Randy
Old 09-16-2015, 05:11 AM   #11
RAG, my leveling jacks acted crazy one time. The front would go down, but the back jacks would not. Then the next try, something else crazy would happen. I turned both the switches off by the manin entrance door (don't remember what they were called, but they isolate the battery when coach is in storage). I left both off for a few minutes, switched back on, and the jacks worked OK. I likened it to rebooting a computer.
We sure enjoyed our 2004 30 Ft./with slide, but sold it this summer and went back to an Airstream trailer. Each type of RV has its advantages!
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
Power Gear Leveling Control Airstream12557 Land Yacht/Legacy Motorhomes 3 04-08-2013 05:09 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
