Old 04-22-2013, 05:20 PM   #1
Off Course's Avatar
2005 30' Land Yacht 30 SL
Jupiter , Florida
Over Filling Fresh Water
OK, so I am learning everyday about the LY. This weeks lesson is shes not a boat. Needed to fill my fresh water so I put the hose in the fill and went inside to do a little clean up with the wife. A few minutes later she yelled from the rear bedroom that the hose outside was spewing everywhere. I figured no big deal and went out and shut it off. Roll the tape forward a day or two and the MH has the odor of must. Yep, you guessed it, the pressure overflowed under the bed and I have been three days setting fans up to dry her out. Note to self: stay by the hose when filling and don't over fill!
Off Course is offline   Reply With Quote
Old 04-22-2013, 06:23 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Dang. Sorry to hear that. Sounds like you have he right recovery plan and a good new chunk of knowledge. I picked up about 600 new ones this weekend :-)
Good luck!
Old 04-22-2013, 06:47 PM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
You need to check out where it leaked in at. I don't think you should get anything wet inside, all the water should of been kicked to the outside overflow, that what mine does anyway.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 04-22-2013, 07:28 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If you push the hose too far into the filler and the vent next to it is blocked by something, it can overfill. Has it pushed up the floor? How did water get inside? I assume the tank is underneath (may not be) and it would be difficult for water to be inside. You'd better track that down.
There is an attachment for a hose that screws onto the end and has plastic tubing small enough to easily go into the filler without jamming in there so that air and water can come out while filling.
Gene
Gene
Old 04-22-2013, 07:39 PM   #5
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
I'm with Gloran. On mine the excess water just spews out the inlet once the fresh water tank is full. There should be no place for the water to enter the unit unless a fitting is leaking. I'd open the area under the bed (assuming that that is where the fresh water tank is) and observe where the water is entering the unit when you reach full capacity. Do keep in mind that the water inlet is not designed to be pressurized so it can blow a coupling going to the vent line. I fill mine with a hose and funnel while leaving a small air gap around the filler hole and adjusting the flow volume so that the funnel doesn't overflow when filling. I have over filled my tank as well, but never had any water enter the unit.
92landyacht is offline   Reply With Quote
Old 04-22-2013, 07:45 PM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Sounds like the fill hose could be leaking where it joins the tank. A common occurence on Airstream trailers. Do not know about MH's. I have had to change the fill hose on 2 trailers.
Old 04-22-2013, 08:16 PM   #7
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
92Land yacht, does your coach have the Auto Fill option? And if does have you tried using it?
Old 04-22-2013, 09:06 PM   #8
Off Course's Avatar
Jupiter , Florida
Whats the auto fill option? Is that part of the system when the main water is hooked up?
Old 04-22-2013, 10:17 PM   #9
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
So I'm confused about how you fill your fresh water.
You said "Needed to fill my fresh water so I put the hose in the fill".
On our Land Yacht, to fill the fresh water tank you hook the "city" water hose to the rig. Then turn the fill valve. When the water comes out of the overflow under the rig, the tank is full and you switch the valve back to the normal position and you are back on "city" (or "park") water.
BarnacleBill is offline   Reply With Quote
Old 04-22-2013, 10:28 PM   #10
Off Course's Avatar
Jupiter , Florida
I am an 05 LY, I'll look tomorrow for the valve. I haven't seen it as yet.
Old 04-22-2013, 11:55 PM   #11
2005 28' International CCD
Camarillo , California
the fresh water auto fill on your rig is to the left of the black water flush intake
loft47 is offline   Reply With Quote
Old 04-23-2013, 07:35 AM   #12
1992 36' Land Yacht
Grayson , Georgia
On mine, the "auto-fill" only fills the fresh water tank to 2/3s full and takes forever. To get a full tank I have to add water to the none pressurized filler opening.
Old 04-23-2013, 08:26 AM   #13
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Off Course, on our LY's the auto fill is a switch located on the Monitor Panel above the stove hood. What this switch is suppost to do is when hooked to city water at camp ground or where ever, and you want to put water in your fresh water tank, by turning on this auto fill switch it will fill your water tank to 3/4 and then turn off water filling on its own. You have the convience of not having to watch it, and if you don't like traveling with a full water tank, you don't have to keep checking the Monitor Panel to see what level you have.
Old 04-23-2013, 08:42 AM   #14
1992 36' Land Yacht
Grayson , Georgia
On most of my trips with the LY I'm boondocking so I like to carry as much water as she can hold. Black and grey tanks empty and fresh water full is the way I leave for a trip.
Back on topic, I still feel that there must be a loose connection or a cracked water line if you're getting significant water intrusion when filling the fresh water system.
