Old 03-16-2016, 10:57 PM   #1
Registered User
1996 30' Land Yacht
Benson , Arizona
O'Reilly Control Arms?
Decided to bite the bullet and go thru the front end. The closest place has everything in stock is O'Reillys. They sell a house brand of control arms (with ball joints and shaft) called Precision,; prices are about 2/3 of what I have always used in the distant past... Moog.
The biggest visual difference appears to be that the Precision are pressed in ball joints - just like OEM. While the Moogs are bolt in. If you were just going to replace a failed ball joint, bolt-ins are much easier... been there, done that.
That said, the Precision does have a lifetime warranty...of the part. No labor reimbursement; which is where most of the $$ would be if this had to be done again in a few years.
Anybody done this lately, with hardware comments?
TIA
pago cruiser is offline   Reply With Quote
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Replacing Awning Arms beachmpk Awnings 7 10-05-2004 01:28 PM
use of lift arms whistler Hitches, Couplers & Balls 4 12-27-2003 08:14 PM
Awning arms Doug Diepenbrock Awnings 1 08-06-2003 02:04 PM
