Old 05-01-2013, 11:19 AM   #1
1996 30' Land Yacht
mesa , Arizona
Onan Marquis 5000 Generator problems
Hi all.
I"m new to this forum and new to owning a 1997 LY 30ft. I need some help with my generator that will not start. It will turn over and run if I spray start fluid in the intake. But I'm not getting gas to the carburetor. The tank on the motorhome is over half full so I know that's not the problem. My question is... is there a fuel pump that sucks gas from the main tank to the generator? I'm lost and could use any help.
cruiser1 is offline   Reply With Quote
Old 05-01-2013, 11:24 AM   #2
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
I had a similar problem in my 2004 Land Yacht, but the gas tank was about 1/4 full. After filling the MH fuel tank, the generator started and ran fine.
Has your generator ran recently? Could you have a fuel filter problem? If possible, I would fill the motorhome gas tank and try it again.
Sam
Airstream12557 is offline   Reply With Quote
Old 05-01-2013, 11:25 AM   #3
I forgot; welcome to the forum. The group is very helpful and we all learn from each other.
Sam
Old 05-01-2013, 11:42 AM   #4
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
There is a small fuel pump on mine, it runs when I prime the system. I did have all the fuel evaporate from the genny to the fuel tank during my year in Bullhead City. I used a mity vac to pull fuel into the line up to the carb (a good thirty feet), it took awhile with a bunch of squeezes. I don't think the stock fuel pump would ever overcome that pull.
The gummed up jet in the bottom of the float bowl was the key for me to get it running again
"Chip Tank" is in Carson City Nv.
CDONA is offline   Reply With Quote
Old 05-01-2013, 12:56 PM   #5
1996 30' Land Yacht
mesa , Arizona
Hi Sam,
Not sure when the last time the generator ran. I'm going to say at lease 2 years ago. The fuel tank is 3/4 the way full right now. But I will have to try to filling it all the way up. I wasn't sure if there was a fuse somewhere that I was missing. We tried priming the line and was able to get a little bit of fuel to run out. But that was about it.
Old 05-01-2013, 01:47 PM   #6
2000 31' Land Yacht
Fort Erie , Ontario
Welcome to the forum. You could do a search on this site for Onan Marquis and get some info. Check the connectors for corrosion. Given that it sat for 2 years it is a possibility that you have a gummed up carb. Mix a carb cleaner and fresh gas in a separate container and feed directly to the genny carb. See if that helps. Also on the list, change oil, filter and airfilter.
Good Luck
Steve
is.chowa is offline   Reply With Quote
Old 05-01-2013, 01:52 PM   #7
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Disconnect the fuel line from the carb and crank the genset with the fuel line in a jar. See if you get fuel pumped out. If so, it's possible that the fuel in the line is stale or the carb needs to be rebuilt. If the fuel smells bad or is dark then keep pumping in short bursts until you get fresh fuel. You can also let gravity move the fuel out once you get fuel by placing the line and jar as low as possible. You may need to drop the float bowl to clean out any old fuel as well. Either way your goal is to get the stale fuel out. If no fuel after cranking a few seconds then it may be fuel filter or a bad fuel pump. At 3/4 full you should have no issues with dip tube level pulling gas. That's assuming that the gauge is accurate.
Once you do get it started verify you have full AC voltage. If not, your slip ring may need to be cleaned. Very common problem if a genset has sat for any period of time. It's the main reason that all gensets need to be
exercised once a month.
92landyacht is offline   Reply With Quote
Old 05-01-2013, 03:15 PM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If the above good suggestion don't work, no fuel sucking in, it might be that it can't get into the carb, bolt under carb bowl on older models, drops it, carefully not to crush or destroy the o ring at top edge, if you have room you can drop the needle valve located above the float, squirt wd40 into the area, also take out the air adjustment needles do them.
I found seafoam from auto parts store great to mix in the jar of fuel if it is being pulled thru.
I have had genset not starting but making starting noises when battery connections or low voltage is present and not spinning fast enough to start, you might be able to use the switch on the dash to connect all batteries to help start it.
Great way to use the forum, lots of backyard mechanics on this site, good luck and happy cruising.
Old 05-02-2013, 07:41 AM   #9
1996 30' Land Yacht
mesa , Arizona
Thanks everyone for the tips. I'm going to remove the fuel line from the generator and install it in a jar and see if that work. I will keep you posted.
Norm
Old 05-02-2013, 07:59 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If the last fuel put through the generator contained ethanol, that's not a possibility, it's a guarantee.
Cats and ultraleather Airstream upholstery don't mix!
Old 05-02-2013, 09:57 AM   #11
1992 36' Land Yacht
Grayson , Georgia
"Also on the list, change oil, filter and airfilter."
Speaking of oil, you may want to check the oil level. On most Onan models you must have enough oil (when the unit is level) or the unit will not start. Most likely not your main cause but also a posibility.
Old 05-03-2013, 09:50 AM   #12
1996 30' Land Yacht
mesa , Arizona
OK after messing with the generator last night I believe the fuel pump if bad. Me and a buddy ran 12 volts right to the pump and all we got was a clicking noise coming from the solenoid. Also with me touching the solenoid while he turned it over there was no clicking that I could feel. We had 12 volts going down to the fuel pump when turning over generator. So I believe it has to be the fuel pump. Would you guys agree or can I be missing something? If so. I have seen you can just pick one up at Auto Zone or O'Reillys for cheaper.
Old 05-03-2013, 10:47 AM   #13
It's a start. That's the thing about troubleshooting; the first problem you find isn't necessarily the only problem. After you replace the fuel pump, you may still find the carburator gummed up, or whatever.
Old 05-03-2013, 12:04 PM   #14
CDONA's Avatar
I bought another fuel pump because I couldn't hear/feel the stock pump run. Plugged in the new one, same results. it wouldn't pull the thirty feet of empty fuel line. When I did get fuel to the pump it did work, so I tried the original one and it worked too. My experience, get fuel to the pump first, then clean the main jet in the bottom of the float bowl.
