Sticking needle valve staying open or float saturated so that needle valve can't close would do that. Try the seafoam in a jar of fuel and run it into the carb, might free it up other wise you are looking at a rebuild for the carb.
Read all the previous posts on this site about onan should solve your problem. Onan+gas + alcohol = problems for gaskets and crud in carb bowl.
