Old 03-12-2007, 05:30 AM   #1
1995 31' Land Yacht LE
palm harbor , Florida
Onan Generator - Help
I have a 1995 Gas Landyacht with an Onan Generator that was working fine until this weekend. The generator starts ups fine but there is no AC. Can't run the AC and some of the outlets are not working. The circuit breakers are good. The circuit breaker panel is located on the front side of the bed.
Is there a circuit breaker that I might have missed? If the circuit breakers are good what other type of problem might there be?
The generator is serviced every year.
Gail
Palm Harbor, FL
gdeterra is offline   Reply With Quote
Old 03-12-2007, 05:57 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Yes, your are missing it
There are two push button breakers on the right side of your generator. One is for your second Air Conditioner and the other is for your receptacles.
The buttons look like those reset switches you see on small portable heaters.
Or they may look like typical breakers.
smily is online now   Reply With Quote
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Switch out Onan 4.0BF genset? abridges01 General Motorhome Topics 8 09-26-2006 07:28 AM
Onan Genset not starting Nick Danger Mechanics Corner - Engines, Transmission & More... 8 04-15-2006 07:40 PM
onan troubleshooting help rcaldwel Generators & Solar Power 2 03-10-2003 05:00 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
