Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 05-03-2014, 09:19 PM   #1
Johnsito's Avatar
1997 31' Land Yacht
Onan generator breaker issues
I have a 1997 Land Yacht with an Onan 5000 generator. A few weeks ago, the generator was running, then shut down and would not restart. I changed the oil, oil filter and air filter. I have plugsand was going to change those next, but decided to try and start after this first phase. When I did, the generator started to crank, but then stopped Andalusia clicking noise comes from the breaker box. I turn the breaker switches off, then on, and the same issue occurs, which tells me that the switches are tripping when I try to start it. No appliances are on in the RV. What could be causing the breakers to trip?
Johnsito is offline   Reply With Quote
Old 05-25-2014, 08:24 AM   #2
Johnsito's Avatar
1997 31' Land Yacht
Has anyone ever experienced this issue? All fuses are in good shape also.
Old 05-25-2014, 09:46 AM   #3
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
More detail on which generator you have please. Model number and serial number would help.
92landyacht is offline   Reply With Quote
Old 05-26-2014, 06:56 AM   #4
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Once, mine would not start. I found the problem to be that the fuel level was too low in the coach gas tank. It has to be somewhere about, or above, a quarter of a tank.
Airstream12557 is offline   Reply With Quote
Old 05-26-2014, 10:14 AM   #5
Johnsito's Avatar
1997 31' Land Yacht
Thanks. Yes, ours will go out if the fuel tank is below half. Fuel level is full. Interestingly, it will now start, but only if I start the RV engine first, and if I then turn the engine off, the generator,will shut down. This sounding like a battery issue maybe?
Old 05-26-2014, 10:32 AM   #6
Johnsito's Avatar
1997 31' Land Yacht
It is an Onan Marquis 5000
Old 05-27-2014, 08:42 AM   #7
1992 36' Land Yacht
Grayson , Georgia
Need the complete model number and serial number off the metal plate. I'm trying to run down the service model for your genset but they made several model Marquis 5000's over the years.
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 10:25 PM
Weak breaker on Generator xtian999 Generators & Solar Power 2 05-27-2013 10:51 PM
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 10:43 AM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 10:37 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 02:51 PM
