Old 08-16-2006, 01:45 PM   #1
gunworks's Avatar
1995 35' Land Yacht Diesel
Noblesville , Indiana
Onan Generator
Recently returned from short trip to Michigan, where we did not use the generator very often. Upon return to the Muggly Midwest, I was not able to immediately hook up to my shore power so started the generator to run the rooftop A/C unit to keep coach cool. Generator sounded like it was running rough at first then settled down and was smooth running, but noticed a very pronounced rotten egg smell. This was not coming from any noticeable source, but it did fill the whole coach. It did not appear to be fronm the A/C unit, refrigerator or any plumbing drains (tanks emptied on way home). I have not tried to repeat the effect just yet, but wanted to know if anyone has had a similar experience and would like to share. Suggestions welcome!
95 Landyacht
gunworks is offline   Reply With Quote
Old 08-16-2006, 04:39 PM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
onan generator
you might check your battery. rotten egg smell sounds like the batteries may be overcharging. check voltage at battery.
arodriguez60 is offline   Reply With Quote
Old 08-16-2006, 06:53 PM   #3
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
My gen set is propane operated is yours? The smell could be a propane leak.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-16-2006, 08:54 PM   #4
gunworks's Avatar
Onan Generator
Mine is also propane, but this does not smell like gas and it stops when generator shut off. Batteries are sealed AGM type batteries. Smell does not come from front bonnet, I checked. I suppose it could be the starting battery as I did not check it. That will be next item to check. Thanks for suggestion.
95 Landyacht
Old 08-18-2006, 08:16 PM   #5
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
I always thought that the "Rotten Egg Smell" was unburned propane.
Sometimes I get that to when starting the Onan. I figured it flooded or got more propane than it could effectively burn and that resulted inthe smell.
I think I'll ask the propane place, I don't want to fool with anything that explosive.
Paul
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 08-18-2006, 10:20 PM   #6
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Check your propane level
When the propane tank runs low, there is a pronounced smell of rotten eggs. You might want to have a certified gas tech look this over - keep in mind that, if your LY is set up like mine, the generator runs on liquid propane, while the hot water tank, refer and stove use propane vapour. You should see two valves coming out of the propane tank (located just in front of the entry door on the curb side). There is also a gauge on the tank there, in addition to the test switch on the panel above the stove.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 08-23-2006, 01:49 PM   #7
gunworks's Avatar
Propane level
Yep, mine is set up the same. Level is down to about 1/4 so that may be the answer. I am going through a troubleshooting exercise with the inside monitor panel as it always reads full, no matter what the tank guage reads. FYI inside panel was made by Ventline, and they are very helpfull. I will be getting the tank filled next week and will see if the smell persists. Thanks for your input.
95 Landyacht
Old 07-22-2009, 08:46 PM   #8
colorado springs , Colorado
i think hes right on the batt.
check the batt. that sounds right to me
simmsmel is offline   Reply With Quote
Replacing Onan for a portable generator Paul Daugherty Airstream Motorhome Forums 7 06-15-2012 08:43 AM
Onboard generator bhsl8 Generators & Solar Power 39 07-29-2003 05:31 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
