Old 02-25-2008, 12:11 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Old TV OUT
I want to replace my glass tube front TV in my 2002 Land Yatch 30' MH with a flat panel LCD. Has anyone with this model done that yet? Steve
spat61 is offline   Reply With Quote
Old 02-25-2008, 01:38 PM   #2
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
See "10 Yr. Old Cutter.....Now What"
No pictures posted yet but sounds like maybe what we both need / want
My 2002 LY350 also has this 19 inch Sony Tube,it is in the dash, right over the dog house
Now that the HD-LCD's are out I want to do the same, but the bracket I would want to be able to raise the flat panel "in elevation" so while sitting on the couch or at the table you don't have to look down maybe so the bottom of TV is top of dash??
anyway if you find anything please let me know
myfirstrv is offline   Reply With Quote
Old 02-25-2008, 03:06 PM   #3
reday's Avatar
Old Hickory , TN
Me too...
Looking at doing the same thing and have not come up with a final plan yet. When I bought my '03 (used), AS had just moved to a flat screen mounted over the dinette and had "converted" the place where the tube set was located in the dash into storage. I did not care for it. The TV location in the kitchen was all wrong too. I am thinking about the flat screen in the dash location, but on an articulated mount that could be raised and pivoted manually. I did this on a truck camper and used my computer (Mac) as a TV (using eyeTV converter) and did music (iTunes), DVD and computing (wireless mouse and keyboard) all through the one screen. If I did this again, I would mount the computer and a dedicated inverter in the space behind the screen... until then, I might just use a digital converter box when over the air analog goes away next year.
Ralph & Margie Day
Lizzy the Borderline Collie
Old Hickory, TN
Between 'steams...
reday is offline   Reply With Quote
Old 02-25-2008, 04:09 PM   #4
myfirstrv's Avatar
Vermilion , Ohio
So the key to this might be Find the bracet (articulated mount ) first then do some type of cabinet work
Old 02-25-2008, 04:32 PM   #5
reday's Avatar
Old Hickory , TN
Yup
Sounds like a plan. Something like the VM-3 from Sanus gives you everything but the ability to raise and lower height... I have not figured that out yet.
$109 on their web site
Product Type Specifications
TV Size Range 13" - 30" / 33.02 - 76.2 cm
Maximum TV Weight 30 lb / 13.61 kg
Mounting Pattern
100mm x 100mm
75mm x 75mm
Tilt Range +15 / -15
Swivel +90 / -90
Pan +90 / -90
Roll +0 / -0
Ralph & Margie Day
Old Hickory, TN
Between 'steams...
Old 02-25-2008, 07:06 PM   #6
Santart's Avatar
2000 31' Land Yacht
Kerrville , Texas
TV location must be a universal dislike on these Land Yachts. I was originally thinking I would put a flat panel LCD over the chair next to the door, and hang it from the cabinet above. It would cover the window but since that window does not open and is usually obscured by the open door, it is not a problem and we could sit on the sofa looking straight ahead. Since then I removed the chair and am considering mounting it on the wall below the window. I only wonder how difficult it will be to get the cable from the antenna routed to it. Could probably go through the wall right of the passenger seat. The space where the old TV was will make a good storage cabinet for the Airstream manual which will fill half of it.
AIR# 7463
Frank & Angela
2000 Land Yacht 30 MH
Texas Hill Country
Santart is offline   Reply With Quote
Old 02-25-2008, 07:11 PM   #7
myfirstrv's Avatar
Vermilion , Ohio
Mini wine fridge ??
Old 02-25-2008, 09:12 PM   #8
reday's Avatar
Old Hickory , TN
I like that...
I had thought about a wine rack! Like the fridge better.
Frank, you remember I moved the chair too (you for your cat & me for the dog). I have a small chest there now that a flat screen could be mounted on. Would probably re-route antenna on around through the dash and under the trim I have covering the flooring beside the passenger seat. It could also be re-routed easily under the coach and up through the floor.
Somebody just needs to lead the way...
Ralph & Margie Day
Old Hickory, TN
Between 'steams...
Old 02-26-2008, 05:50 PM   #9
myfirstrv's Avatar
Vermilion , Ohio
My LY has a composite arm rest on the drivers and curb side that goes all the way to the floor and just past the rear of the passenger seat so running cable power is no worries, and behind the passenger seat I have the barrel chair and window kind of same spot as Frank was talking about.
Except my window opens and Grandma sits in the chair so don't really want to block the window
Was thinking about from the cabinet above the dash but hate the idea of the weight ??
So I guess I'm back to replacing the tube TV, maybe Two brackets, one just to lift it up and they the second that attachés to that ????
just thinking out loud.
Old 02-26-2008, 06:57 PM   #10
Santart's Avatar
2000 31' Land Yacht
Kerrville , Texas
Don't you have an end table to the left of the barrel chair? Maybe you can mount a TV on a swivel so it is across from the sofa, and encroaches on the door just a bit when rotated. Or, maybe mount it under the cabinet above and travel with it in a position where it can be seen from the kitchen, and swing it to sofa viewing position when you are all watching. Just thinking quietly...
AIR# 7463
Frank & Angela
Texas Hill Country
Old 02-27-2008, 06:33 AM   #11
myfirstrv's Avatar
Vermilion , Ohio
[IMG]file:///C:/1_Rob/camping/rv/Copy_of_1robs_rv_2000_airstream/100_2524.jpg[/IMG]
Old 02-27-2008, 06:36 AM   #12
myfirstrv's Avatar
Vermilion , Ohio
My layout is a little different
Passenger side from front to rear
Passenger captain chair
barrel chair
steps
short wall
dining table
re fridge
Ill try to post picture
Old 02-27-2008, 06:50 AM   #13
myfirstrv's Avatar
Vermilion , Ohio
see attached
Old 02-27-2008, 06:55 AM   #14
myfirstrv's Avatar
Vermilion , Ohio
Let me know if you can open the two files I sent
I have no idea how I did it, or if its correct
This computor stuff is for the birds
