Old 02-27-2008, 07:57 AM   #15
Santart's Avatar
2000 31' Land Yacht
Kerrville , Texas
Originally Posted by myfirstrv
Let me know if you can open the two files I sent
I have no idea how I did it, or if its correct
This computor stuff is for the birds
I was able to see a single image on each PDF but I understand the setup. My best suggestions are as follows: A. Make use of the divider between the steps and the dinette by mounting a set on top with a swivel. When turned toward the sofa, it will encroach just a little into the stairwell and it can easily be turned toward the kitchen/dining area as well. You would be limited to a set no wider than the divider wall. B. I believe the barrel chair slides forward so mount it under the shallow cabinet above and swivel the chair to face the kitchen. Try to find a mount that will allow it to pull out and swivel as well. I am not certain there is such a mount but a little searching will tell. As I am writing, I see the complexity os B. and the simplicity of A. All these failing, C. would be to store the TV in place of the tube set, and make it so it can be easily removed to sit on or in front of the doghouse when you are parked and settled in. These sets are very light weight and that would be the easiest of all, but will require turning your head to the left albeit not as much.
AIR# 7463
Frank & Angela
2000 Land Yacht 30 MH
Texas Hill Country
Santart is offline   Reply With Quote
Old 02-27-2008, 09:12 AM   #16
reday's Avatar
2003 31' Land Yacht 30
Old Hickory , TN
Ram Mounts
Check these guys out. I have used their stuff for lap tops, GPS's, depth finders and fishing rods. They have something for about anything you want to mount. You could attach a Vesa plate/ball to the screen and move it to multiple locations that you run antenna to if you wanted.
I need to stay up front with mine since I use the AUX on the radio to feed the TV/DVD sound to. It's not surround, but with the powered sub woofer, it sounds better that the TV speakers. I may end up storing the screen for the ride and attaching it with something from their extensive catalog at the camp site. I can see a pipe base mounted to the dog house that would raise the screen above the dash (or suspend downward from the cabinets over the dash?) with a swing arm for side to side movement terminating with the vesa/ball to the screen...
RAM Mounting Systems, Inc.
Ralph & Margie Day
Lizzy the Borderline Collie
Old Hickory, TN
Between 'steams...
reday is offline   Reply With Quote
Old 03-18-2008, 01:00 PM   #17
reday's Avatar
Old Hickory , TN
Another Mount...
I just ran across another mount that is worth looking into. Camping World is carrying Thule's Smart RV line. It is called the Smart RV LCD TV Post #5580. You can see it at Thule SMART RV
If you look under the customer service tab then Instructions, you will see how it works. With additional RV Pod kits, you can have multiple mounting locations... Think inside/outside RV along with the patio or garage at home.
Think I'll take a look next time I'm by CW.
Ralph & Margie Day
Old Hickory, TN
Between 'steams...
