Old 07-01-2014, 11:54 AM   #1
2003 31' Land Yacht 30
amelia island , Florida
oil change light on
Know I have read somewhere how to fix this but can't find it. The whole time rig is on, the oil change light is also on. Please tell me how to reset it.
snickers is offline   Reply With Quote
Old 08-03-2014, 05:02 PM   #2
normandgrace's Avatar
2005 33' Land Yacht Gas 33
pembroke pines , Florida
Snickers, check your workhorse manual for the correct sequence to turn the light off. Download manual if needed as each model year is probably different if changes were made to the chassis. Good luck!
normandgrace is offline   Reply With Quote
Old 08-03-2014, 07:12 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Try turning the ignition switch on, then push the throttle to the floor and release three times, then turn the switch off.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
Duramax oil change BillTex Tow Vehicles 35 04-23-2009 11:50 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Oil Change Fear and Woes Chaplain Kent Classic Motorhomes 14 04-09-2006 07:09 PM
Should I change my oil? Turtle Mechanics Corner - Engines, Transmission & More... 18 07-07-2004 12:18 PM
