Old 06-26-2015, 07:48 AM   #1
1998 31' Land Yacht
Lake Odessa , Michigan
No Water at Faucets
I m not hooked up to a water supply just using from my tanks. I have good water flow at the toilet and shower a few dribbles at the bathroom sink and nothing at the kitchen sink. Any suggestions to help?
btuinstra is offline   Reply With Quote
Old 06-26-2015, 07:52 AM   #2
2010 27' FB International
La Crescent , Minnesota
Check the aireators for hard warer deposits. Clean and reinstall
Jay
mjayjensen is offline   Reply With Quote
Old 07-01-2015, 09:05 PM   #3
kenajen's Avatar
1972 23' Safari
2005 30' Land Yacht 30 SL
Miamisburg , Ohio
What year and model? The 2005 Land Yachts have a Moen Faucet with a water filter in the faucet.
kenajen is offline   Reply With Quote
Old 07-03-2015, 10:32 AM   #4
2000 31' Excella
Ontario , Canada
I would hook up to water supply to see if that changes water available at washroom and kitchen sink.
If not then you have a blockage. in piping or at the taps.
If water now flows from washroom and kitchen taps, then I would suspect the pump/ fresh water tank for crud. or pressure valve?
woodytwo is offline   Reply With Quote
Old 07-04-2015, 07:22 AM   #5
1998 31' Land Yacht
Thanks for the response. In fact did have a blockage at the faucets. I cleaned the screens and all is fine!
Old 07-05-2015, 04:15 AM   #6
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
When winterizing, I try to remember to remove all the aerators at the faucets before blowing out the pipes. I have had the saqme perplexing problem in the Spring!
Airstream12557 is offline   Reply With Quote
Water leaking from belly, doesn't make it to faucets. Ddanielgriff Fresh Water Systems 3 09-29-2013 08:10 PM
Water Pump Vomits water out of faucets! thoreaulycra Water Heaters, Filters & Pumps 5 12-19-2008 11:12 PM
no water from curb side faucets lefthandtim Plumbing - Systems & Fixtures 6 10-06-2008 05:37 PM
HELP-No water in any of the faucets??? shinybean Fresh Water Systems 10 11-23-2006 09:14 PM
Water faucets otha1 Sinks, Showers & Toilets 5 08-31-2003 10:05 AM
