Old 07-26-2014, 02:25 PM   #1
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
No pressure reading on TAG suspension
Last trip out I noticed that the pressure gauge showing the TAG axle pressure never got above 10psi.
Any ideas on where to start looking for this? The air horns were still working and they run off of the same compressor and need more then 50psi to blow so I'm sure the compressor was building pressure.
92landyacht is offline   Reply With Quote
Old 08-06-2014, 11:08 AM   #2
1992 36' Land Yacht
Grayson , Georgia
Problem resolved. Seems like the 1/8" capillary tube that runs to the gauge had a small hole in it from rubbing over the years. Used a 1/8" press on union to do the repair. Just cut the hose at the hole and inserted the union. Started up the compressor and pressure rose to about 70psi. Shut it down and not a sign of a leak anywhere. Over night the pressure dropped about 5psi. Looks like the problem is resolved.
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
Land Yacht Tag Axle Air Suspension Info. mortond Land Yacht/Legacy Motorhomes 0 04-03-2010 12:53 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
