Old 02-20-2013, 05:17 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by AdamB View Post
Make sure they pressurize the coach with air and use soapy water over all of the roof vents (skylight) and side windows to identify & repair leaks.
A motorhome doesn't have to be airtight in order to be weather-tight.
I've heard of people taking the motorhome to a truck wash and aiming high-pressure water at windows and skylights to see if they leak, but this is the first I've heard of pressurizing it and using soapy water, as if the motorhome was a flat tire.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 02-21-2013, 08:53 PM   #16
Registered User
1996 32' Cutter Bus
Petaluma , California
Images: 34
Hi Protagonist,
Having a similar coach which is a similar age as the original author of this thread, I was trying to get across that the number one problem that will most likely be experienced are leaks from many sources. Identifying and repairing the sources of these leaks will be crucial to a happy and less troublesome motorhome experience. I did not state anywhere in my post about the necesity of having an airtight motorhome.
This service is increasingly available at many rv repair shops. For example:
RV LEAK FINDERS - Home
Sealtech Manufacturing Inc. - RV leaks bubbles recreational vehicles
Seal Tech Rainwater Leak Test
Cheers!
AdamB is offline   Reply With Quote
Old 02-22-2013, 02:36 AM   #17
Hi Protagonist,
Cheers!
I misunderstood when you said "pressurize". I stand corrected.
WBCCI #1105
TAC LA-4
Old 02-22-2013, 04:46 PM   #18
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Everything in life that's worth anything has challenges...that includes leaks!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
