Old 03-09-2014, 08:41 AM   #15
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
My outside faucet only works with city water
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 03-10-2014, 09:48 AM   #16
1994 33' Land Yacht
bloomington , Illinois
What size eternabond tape did you use ? They have 8x50 for the same price as 6 inch .would 4 inches be enuff to cover each side rails ? Or should I just purchase 2 6 inch rolls
bertha 94 is offline   Reply With Quote
Old 03-11-2014, 04:13 AM   #17
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
"My outside faucet only works with city water"
I think the poster was suggesting using your water pump in the MH to pump water from the fresh water tank out the faucet.
As an aside, this faucet connects to a flush next to the faucet that leads inside the black holding tank. It should be used after draining the black tank to help rinse it. Also, close the gray tank drain valve before opening the black tank valve. I don't want black water in my gray tank!
When winterizing, I open the drain valves at the foot of the bed at a stop a few hours from home and let the tank and lines drain as driving. The action of the roads help drain all the water.
Sam
Airstream12557 is offline   Reply With Quote
Old 03-11-2014, 05:56 PM   #18
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Sam, I was suggesting using the water pump to drain the fresh water tank. But I don't think this faucet is connected to the auto flush for rinsing the black tank. Your suggestion of opening the fresh water valve a few hours while driving is a good idea.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 03-12-2014, 03:46 AM   #19
You are correct, the faucet in the outside compartment (at least in my rig) is not physically connected to the black tank flush. The faucet has to be connected to the tank flush with a hose. I keep a short hose (about 12 inches long) in the compartment where the faucet is located.
Sam
Old 03-12-2014, 04:13 AM   #20
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
If you need to flush your tank just open the valve it doesn't take that long, maybe a cup of coffee drank.
Old 03-12-2014, 05:51 PM   #21
1994 33' Land Yacht
Im in the process of taking care of leaks and i noticed some water around the coach windows I understand that I should remove the windows and replace the seals? what should i use?
Old 03-14-2014, 06:48 AM   #22
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
If you're talking about the side windows in the coach section then you use butyl rubber tape. It's cheap (around $5-$10 a roll) and works great. I used 3/4" width and trimmed off the excess.
Here's what it looks like:
92landyacht is offline   Reply With Quote
Old 03-14-2014, 10:00 AM   #23
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
I got my butyl from a metal roof supplier. They have 1/2 inch.
Old 03-14-2014, 10:43 AM   #24
1994 33' Land Yacht
Awesome info thanks guys ! I have also decided with advice from a few roofer buddy's to replace my roof . I just purchased dicor epdm rubber roof kit the rolled membrane style for 500$
Old 03-14-2014, 12:33 PM   #25
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
The you can rebuild the roof decking and replace the sheathing.
Old 03-14-2014, 09:50 PM   #26
1994 33' Land Yacht
You mean tear off fiberglass where the luane is bad and replace luane then rebuild with resin where you tore off fiberglass? Because I had planned on tearing all of the fiberglass and luane off and replacing with a epdm . I found a place that did it to another 94 ly he has a Facebook page ..Lackeys rv service .He has picks of the ly
Old 03-14-2014, 09:53 PM   #27
1994 33' Land Yacht
Haveing trouble posting pics from phone I want to post pics of first project .had to replace fuel filler neck hose . That. Was fun not!
Old 03-15-2014, 07:43 AM   #28
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Images: 49
yea replace the whole roof and repair the rotten wood trusses if any. Make sure they go thick enough luan to walk on.
New member questions Mockinbrd Sprinter and B-van Forum 23 09-04-2011 02:18 PM
New Member with Lots of Questions! quercusgirl Member Introductions 11 07-11-2011 09:22 AM
Trusted Member donschweika Forum Admin, News and Member Account Info 6 02-17-2011 03:40 PM
