Old 10-04-2013, 01:21 PM   #1
JMSx2's Avatar
2005 30' Land Yacht Gas 30
Belgrade , Montana
New carpeting and vinyl plank flooring
After reading for months about vinyl replacement flooring we took the plunge with a HD traffic master product. $200 in materials and $800 to install both carpet and vinyl floor. Need to place quarter round where needed. Very pleased when all said and done.
ID:	197041   Click image for larger version
ID:	197043   Click image for larger version
JMSx2 is offline   Reply With Quote
Old 10-04-2013, 01:23 PM   #2
dougandlori's Avatar
2004 28' Classic
Fresno , California
It looks great. Hope you enjoy!
dougandlori is offline   Reply With Quote
Old 10-05-2013, 04:27 AM   #3
Airstream12557's Avatar
2015 30' Flying Cloud
Evansville , Indiana
Install and material look great! Why would Airstream want to put carpet in an RV??? Throw rugs are much easier to manage.
I assume you decided to leave the carpeting on the engine cover and in the bedroom?
We left the carpet on the engine cover and on both sides of the bed. We extended the cork floor covering to the end of the bed, straight across to the walls. When I winterized once, I spilled some antifreeze solution at the foot of the bed and soiled the carpet. Was hardly noticeable, but while replacing flooring, we did that small area.
Sam
Airstream12557 is offline   Reply With Quote
Old 10-05-2013, 02:15 PM   #4
JMSx2's Avatar
Belgrade , Montana
Kept the carpeting in the front of the MoHo and replaced the carpeting in the bedroom. Good idea to replace the carpeting at the foot of the bed with the plant flooring. Can still do if the time comes since we have extra flooring left over.
Old 10-07-2013, 05:13 AM   #5
Ready to go campin?
wvabeer's Avatar
1992 33' Land Yacht
Evans , West Virginia
Images: 49
Looks great, The front part I think is going to be harder, thats why I haven't done mine either
92 Landyacht 33, 454 tag axle
wvabeer is offline   Reply With Quote
Old 10-07-2013, 06:22 AM   #6
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Good job.
Same here on the front carpeting. Re-carpeting the front seems like a lot of cutting and stapling. Maybe a project for next year. Right now I'm getting her ready for a trip to Road Atlanta for the Petit Le Mans.
92landyacht is offline   Reply With Quote
Old 10-07-2013, 07:19 AM   #7
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
JMS, the new flooring looks fantastic.
We replaced everything (except the bath rm.) with carpeting 2 years ago & the installer commented on the front area taking as long as the rest of the coach. He removed the captain's chairs & dog house cover, but, still a lot of tricky work.
Schools Out is offline   Reply With Quote
Old 10-07-2013, 08:21 AM   #8
JMSx2's Avatar
Belgrade , Montana
The front carpeting is in really good shape. There is good plastic liner at the drivers's compartment; the passenger feet area has a small rug and we have a small rug below the doghouse that we step on to get to the seats. So unless we have a major coffee spill, the carpeting stays!
Old 05-19-2014, 05:06 PM   #9
1997 31' Land Yacht
Mahone Bay , Nova Scotia
Very nice. We have ordered planks for our floor too. We like your flat bathroom floor - we have an extra bump up behind the toilet for furnace and ?? - we haven't taken that apart yet to see if we can eliminate it.
Nice looking coach!
wheelygoode is offline   Reply With Quote
Old 05-19-2014, 05:10 PM   #10
1997 31' Land Yacht
Is your cork flooring glue down tiles or click flooring? I liked the look of the cork click flooring but was wondering how it would be in the bathroom/shower area, and if the wider planks would be harder to install than what we ended up ordering which is something like allure flooring with the individual planks. We're allowed to change our minds as what we ordered was actually overstock in one of their other locations.
Old 05-19-2014, 09:00 PM   #11
2000 31' Excella
Ontario , Canada
I agree, the flooring looks great.
I'm going to take up the challenge of new carpet in the front in the fall. Any idea how he removed the captain chairs? I would think that once you removed the captain's chairs and old carpet it would be fairly easy to put the carpet down. The dog house is another challenge all on its own because of the different levels and sloping floor. But it is easy to remove and then do the work on a workbench. I assume that under the existing carpet there is a plywood floor. Might be just better to remove the chairs, all the carpet and underlay and then have a carpet guy install. Any insight that anyone can share would be appreciated. Thank you.
woodytwo is offline   Reply With Quote
Old 05-20-2014, 04:49 AM   #12
1997 31' Land Yacht
The captains chairs are on with 4 bolts - just undo the bolts and lift off the chairs.
That will be the easy part......
Old 05-20-2014, 05:09 AM   #13
Rockford , Michigan
Images: 12
Woodytwo, I watched them remove the captain's chairs & was surprised at how easy a job that was. The chairs are bolted to a base plate…so, he removed the nuts & unplugged the electrical connector. The electrical connector is a click together type plug. (sorry, I don't know the correct term) When the hardware was off & the electric unhooked, the chairs were lifted off the base. Seemed easy for 2 guys.
Re: the dog house. The pro did exactly what you are thinking. He put it on our workbench & worked on it there. The dog house cover is only glued…no staples or tack strips. I think he used a rubber cement type glue, but I'm not positive about that. The slope of the d.h. didn't make it difficult….its the corners. Briefly, he glued a piece of carpet lager than the cover & clipped the corners to fit. (if you know a sewer they can explain how to remove triangles of material to make a nice, flat seam on a curve.) He let it dry over night, then trimmed the bottom edge of the d.h. cover. Those corners are the only area that I've had to "work on"….I've had to glue each seam, again. Our choice in carpet material, probably, made covering the d.h. a more difficult install. We went with a tight, flat, continuous loop berber. (the hardest type to hide seams…the easiest type to unravel)
Good luck, woodytwo.
Dan's '66 Tradewind Improvements TouringDan 1959-69 Tradewind 197 05-11-2018 06:27 PM
Allure Trafficmaster Vinyl Planks hippiechick Floor Finishes 53 06-09-2013 09:11 PM
Exploding Floor Friday Repairing/Replacing Floor &/or Frame 24 01-27-2012 03:25 PM
Anyone used Konecto Flooring? scotta Floor Finishes 9 03-29-2011 12:59 PM
