Old 10-10-2007, 06:56 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Need help with lights
My AS LY has three front marker lights out. Checked bulbs, one was bad the other two good. Pulled out the lamp assembly and noticed corrosion. I probed the contacts on the inner plug with no voltage reading. This lamp setup is unique. There are no wires, just an inner plug, that I can't get at, and the external portion that plugs into the inner. If I can't get voltage readings, can I try to grab the inner plug, pull it out and hopefully have wires attached to it. Then I could just swap the AS lights for standard markers. Is that feasible? Is there another way to get at these wires? Any help is appreciated. Thanks.
Steve
spat61 is offline   Reply With Quote
Old 10-10-2007, 07:21 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Pull the assembly -
The marker lights rely on the two screws holding the assembly for the ground ( I think with a wire connector for the ground). Since you have a fiberglass roof in this area (I think) you may have an additional point for corrossion problems. If you pull those two screws you should find one wire (the running light circuit) attached to the plastic light body and the other with a round connection to the screw for the ground.
Be careful when taking your readings - good grounding points are notoriously difficult to find.
I would think it unlikely that there is wire damage in the interior - all of the inner wires are fairly well protected.
My gut is that you have corrossion problems with both the ground and positive connections in the bulls eye mount area. I have found that the "standard" bulls eye lenses and mounts are direct replacements on the trailer and classic MoHo. You might consider going to LED's for the replacements.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Lights Always On? The Flintstones Electrical - Systems, Generators, Batteries & Solar 9 02-12-2007 04:25 PM
new lights for my '67 pinkflamingoes Lights - Interior & Exterior 5 11-13-2005 05:15 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 09:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 07:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 07:43 PM
