Need help with lights
My AS LY has three front marker lights out. Checked bulbs, one was bad the other two good. Pulled out the lamp assembly and noticed corrosion. I probed the contacts on the inner plug with no voltage reading. This lamp setup is unique. There are no wires, just an inner plug, that I can't get at, and the external portion that plugs into the inner. If I can't get voltage readings, can I try to grab the inner plug, pull it out and hopefully have wires attached to it. Then I could just swap the AS lights for standard markers. Is that feasible? Is there another way to get at these wires? Any help is appreciated. Thanks.
Steve
