02-14-2012, 02:58 PM
1992 36' Land Yacht
Grayson
, Georgia
Need help finding weather stripping
I'm looking for a source for the rubber outside window seal weather stripping for my 92 36' LY. It's rubber piece that seals against the outside of the window and the window frame. All the weather stripping around my windows has shrunk over the years leaving sags in the corners and gaps at the bottom. I just figured that, while I'm in the process of sealing her up and rebuilding the inside walls I've just replace these for good measure.
02-14-2012, 03:32 PM
1969 23' Safari
Raleigh
, North Carolina
out of doors mart should have it.
02-14-2012, 03:40 PM
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
Inlandrv.com is a great place to get seals. I told them the year and size of trailer. They knew the sizes of each window and sent the right length. Less work for me.
Judging a person does not define who they are, it defines who YOU are.
02-15-2012, 07:31 AM
Streamin'
1995 30' Cutter Bus LE
Madison
, South Dakota
You may have tryed this, but I found the rubber around th glass just pushed back in on my '95.
02-15-2012, 08:19 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
02-15-2012, 09:37 PM
1993 33' Land Yacht
Midland
, Michigan
O my 1993LY I have HEHR windows. You can contact them direct, they sell the moldings off the spool by the lenial ft. I also replaced the plactic gides the windows and screens slide in. Measure your total lenial footage you need for each style of moldings you want to replace and be ready to describe the windows you have as well as the molding shapes and style. They are very helpful.
HEHR INTERNATIONAl INC.
1101 N. OAK RD.
Plymouth IN. 46563-0219
(574) 935-5122
02-16-2012, 07:12 AM
1992 36' Land Yacht
Grayson
, Georgia
Thanks for the help folks. As with any project I seem to do, it always ends up being "Well, while I'm this far I might as well....______". Fill in the blank.
