Originally Posted by bobmiller1
The best system out there is Sea-Level. It only uses 2 wires to connect all the tanks in series. It’s right on the money. Regards, Bob
And it can use the existing wiring. I'm installing a SeeLevel in my Classic. The difficulty in my trailer is the water tank is in a separate cover from the black and gray tanks. I haven't figured out how to get access to it yet. Hopefully I can get enough access to hook it up through an access port a previous owner put in or had put in.
The sensors for the black and gray are accessible through the access port I added to change the dump valves.
Al
