Old 10-29-2018, 10:08 AM   #1
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Mice - Does steel wool in mouse holes rust?
I like the idea of packing steel wool into mouse holes and can understand how this would deter them. However, I wonder if the "wool" would eventually rust out (even if not directly exposed to water but only to moisture in the air).
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 10-29-2018, 10:17 AM   #2
kpm
2018 25' International
Mound , Minnesota
Yes it will eventually rust with sufficient moisture. I have turned to Great Stuff Pestblock. Seems to work ok.
https://www.amazon.com/gp/aw/d/B007TUF0FY
kpm is offline   Reply With Quote
Old 10-29-2018, 10:17 AM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I think regular steel will rust after a while, at least in humid climates. I used stainless steel wool. Some people have used copper wool. I think I found SS wool on Amazon.
SSquared is offline   Reply With Quote
Old 10-29-2018, 10:42 AM   #4
1992 AS Land Yacht 36'
1992 36' Land Yacht
Grayson , Georgia
You can pick up those stainless steel curly scrubbers at most grocery stores. Even Home Depot sells them:
https://www.homedepot.com/p/3M-Scotc...4-16/302127063
jt240z is offline   Reply With Quote
Old 10-29-2018, 11:29 AM   #5
2007 22' International CCD
I use this stuff. Stainless steel material does not rust:
https://www.amazon.com/XCLUDER-RODEN...roof+wire+mesh
Easy to install, and still allows some air flow through the material.
Old 10-29-2018, 11:52 AM   #6
2017 27' International
Lake Havasu City , Arizona
There's an important reason not to use steel wool where it can become damp: it can spontaneously combust.
Rusting gives off heat, like any oxidation reaction. Normally you don't have to worry about this--your steel RV frame isn't going to catch fire, because the amount of heat generated is small compared to the mass of metal. But rusting occurs at the surface of a piece of steel or iron... and thanks to its fine filaments, steel wool has a huge amount of surface area in a small volume, so heat can build up and result in fire. Steel wool burns just fine even when wet; many campers use it for tinder for just that reason.
I know at least one RVer who had steel wool catch fire after using it to stuff potential mouseholes. As others have suggested, use stainless steel, bronze or copper wool/mesh instead.
Paprika is offline   Reply With Quote
Old 10-29-2018, 11:58 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Coarse furnace filter material from HD...👍
“Not enjoying the Network News Broadcast?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 10-29-2018, 12:01 PM   #8
dznf0g's Avatar
Oswego , Illinois
^X2. My stainless pot scrubbers have been in place for 8 years. No rust and no mice....so far....
-Rich-
Old 10-30-2018, 08:23 AM   #9
Thanks to all for your replies. I have decided to purchase copper mesh since I have seen some stainless steel rust over time. Maybe it's cheap SS that rusts. Not certain, but copper should last for a loooong time without oxidizing.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 10-30-2018, 08:29 AM   #10
Acheron2010's Avatar
2018 26' Flying Cloud
Morristown , Tennessee
I've heard the "cure" is to string a set of LED lights under the camper?
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
Acheron2010 is offline   Reply With Quote
Old 10-30-2018, 09:41 AM   #11
Copper may not be the best choice...👎
Furnace filters don't rust at all..
RLC
Amanamus
"Tahawus"
Old 10-30-2018, 10:07 AM   #12
Tom T
Tom_T's Avatar
Orange , California
Just get the coarsest grade of BRASS wool at any home center (Lowes, Home Depot, Ace, etc.).
It will never rust, wont turn green like copper wool, is cost effective & do the same thing as steel wool.
PS - if you're looking for mesh/screen - then get the old school bronze bug screen material at the home center, or a place that does wood framed bronze screens for old home restorations. Coppa in San Pedro CA makes the resto door/window screens, but I don't know if they'll sell just the bronze screen fabric by itself, but should be able to point you to a source to buy some.
Easy Peasy!
Cheers!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 10-30-2018, 10:10 AM   #13
Cerrillos , New Mexico
I use a string of LED lights, about $10 at Harbor Freight, that can be set to blink....which seems to be the best deterrent. Come on at dusk; go off at dawn. I mounted them to a small furniture dolly and put a 2x4 on that as a handle. Slides around anywhich way I want and NO mice or pack rats have been trying to build a nest since.
highfeather is offline   Reply With Quote
Old 10-30-2018, 10:18 AM   #14
1976 31' Excella 500
Chappell Hill , Texas
Yes. Brass Wool like Tom_T says.
tbashin is offline   Reply With Quote
Mouse holes idroba General Repair Forum 5 07-31-2012 01:15 PM
My brother used steel wool on my airstream *eep deelind Cleaning, Stripping & Polishing 9 10-08-2010 09:34 PM
Mice, Mice, Mice Jake General Interior Topics 21 12-01-2009 01:09 PM
compound/steel wool ? gmprejean Cleaning, Stripping & Polishing 5 07-11-2004 08:47 AM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 11:01 PM
