Old 11-17-2016, 07:29 PM   #1
2005 30' Classic
2005 30' Land Yacht Gas 30
Near the water , Wa
Marker/running light issue, any help appreciated!
Had a short in one of the five front top amber running lights. This blew the 10 amp fuse, label mkr in the fuse group left of the steering column. The buzzer that alerts you to having the lights left on now that I repaired light does not work, as well as the rear running lights and the top front group of five. Every thing else on the fuse panel works just fine. So the hazard lights, brake light, turn signal, everything works.
I have checked the engine compartment fuses, and nothing blown there.
Anyone know where the buzzer actually is? Any ideas where the power comes from? I am good for driving in daytime, but until this is fixed, my headlights work, but all the top lights and rear lights don't come on, even though the 10 amp fuse is good and all five top front lights work if I put 12 volts on them from an outside source.
Any one ever had this issue, and what was the solution?
Thanks for any help!
Bella123 is offline   Reply With Quote
Old 11-17-2016, 08:26 PM   #2
2005 30' Classic
Near the water , Wa
Marker lights
This is on 2005 Landyacht, and not finding anything revalent in the landyacht manual.
Old 11-20-2016, 09:12 PM   #3
2005 30' Classic
Near the water , Wa
Found it!
OK, found a wiring diagram for a W22, and the marker lights 10amp fuse also is in series with a 20 amp lights fuse. Checked that, and replacing it brought all the lights back on, problem fixed....just thought I'd mention in case it helps someone else.
Old 11-23-2016, 07:31 AM   #4
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
While working on your marker lights might want to check the rubber gaskets around them. They dry out in the heat and will shrink allowing water to get into the drivers area. They are made by Peterson Light.
Mike1997 is offline   Reply With Quote
Old 12-05-2016, 06:40 PM   #5
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Marker Lights
Mike1997 is on the right track. When the marker light rubber gaskets fails, the wiring and the light fixture itself corrode and short out.
Solution: Go to a truck stop and buy new lights with a footprint that covers the hole in the Airstream roof and replace them. Use plenty of sealant to ensure they stay dry. Don't expect to match them exactly, so replace them all at once. There is a sizable hole under each one and therein lies a big source of leaks that will drip on your dashboard unless you seal them well.
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 12-13-2016, 06:18 PM   #6
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Thanks for following up with the solution.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
1968 Overlander Running Light (Marker Light) Wiring Diagram or Routing Information Bunkroom Lights - Interior & Exterior 2 08-04-2018 01:16 PM
Tow Vehicle Advice... any help is much appreciated! jgpenn Tow Vehicles 30 07-08-2014 08:30 AM
Amber LED Marker running/turn light Dan@LED4RV Commercial Listings 0 07-19-2013 02:20 PM
Newbie Questions -- any help is appreciated! dwy7 Plumbing - Systems & Fixtures 4 02-11-2009 10:13 AM
Newbie Questions -- Bambi Water System -- any help is appreciated! dwy7 1964 Bambi II 1 02-10-2009 10:55 AM
