Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 04-24-2011, 12:55 PM   #1
LaCajun's Avatar
1994 33' Land Yacht
Harvey , Louisiana
LY Hydraulic Leveling System
Need help with my 1994 LY Hyd. Leveling System....on my last trip, went to levele the coach, and nothing....the only thing that was happening is the lights would all blink and would go out immediately...the unit would not turn on. All I could hear was a clicking noise. Sounded like coming from the solinoid, but not sure. Has anyone experience this and is there a simple way to check the system before replacing parts....
LaCajun is offline   Reply With Quote
Old 04-24-2011, 03:00 PM   #2
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
aBad ground, ?
a Loose fitting on the solenoid ? are your coach batteries charged well.
1. check all electrical fittings at the solenoid. what is the voltage at the solenoid.
2. if you have a good 12 volts at the solenoid. the solenoid itself may be Bad.
3. You could jump across the solenoid and see if the Pump activates.
while there on the project. check the Hydraulic fluid level, and clarity. quality.
John H. is offline   Reply With Quote
Old 04-24-2011, 04:35 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Mine have interconnect to brakes. if eb not set, they don't operate. Must be in park to operate, so besides the selenoid you would have to check switch.
Old 04-25-2011, 07:46 AM   #4
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , New Mexico
Post HWH Manuales
What type of leveling system? If it is the HWH 210 SERIES it is the same one we have on our 30' 1995 Cutter LE. I am attaching an Operators Manual pdf and Repair Manual pdf. Check the trouble Shooting sections.
Leveling System Operators Manual.PDF
200_210 Trouble shooting guide.pdf
BarnacleBill is offline   Reply With Quote
Use of hitch system.. KyMoonshine Hitches, Couplers & Balls 14 04-11-2011 10:00 PM
Dual system? Am I going to blow it up? robwok Batteries, Univolts, Converters & Inverters 0 03-24-2011 07:45 AM
System of a grill Jammer Stella's Kitchen 30 02-27-2011 10:15 AM
Leveling system on my 1992 Legacy Desikk Land Yacht/Legacy Motorhomes 0 02-08-2011 01:50 PM
Hydraulic leveling system. boatdoc Jacks, Stabilizers, Lifting and Leveling 18 02-08-2011 05:30 AM
