Old 12-05-2018, 04:15 PM   #1
Robfike's Avatar
1999 36' Land Yacht Widebody
Spencer , Indiana
LY diesel cockpit windows
Anyone know where to get replacement cockpit side windows?
Our new to us 1999 LY diesel has slipping seals between the glass panes.
Thanks!
Robfike is offline   Reply With Quote
Old 12-09-2018, 08:05 PM   #2
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
Their is RV salvage yard in Kentucky.....
VISONERV.com
I would start with them and go from there. If you need other parts for appliances they probably have it too.
Mike
Mike1997 is offline   Reply With Quote
Old 12-09-2018, 08:10 PM   #3
Mike1997's Avatar
Images: 14
Also, you have the 2 year newer sister to my rig. Make sure to check the roof seam for the front cap. Its known for leaking if not maintained. I also found the base to the CB antenna over the passenger seat cracked and leaking. No problems since replaced.
I also removed the old cell phone antenna in center but left the wire in place. Later installed a mobile marine sat antenna for my Sirius radio....works perfect!!
Will be glad to share other tips or answer questions as needed.
Mike
Old 12-10-2018, 05:41 AM   #4
Robfike's Avatar
Spencer , Indiana
Thanks!!!
Iíll check those roof areas. This machine is way different than our 345.
Old 12-12-2018, 08:39 PM   #5
Mike1997's Avatar
Images: 14
Diesel Airstream Landyacht
I changed out the 19" tube TV up front and replaced it with a 24" flatscreen with built in DVD. While the space was open I was warned about the excess ductwork that might be found. Ended up removing 7' of plastic duct which greatly increased the airflow from the dash AC.
Mounted the TV on a computer articulating arm then used Velcro strips around the opening to hold it in place while driving.
Argosy & Classic motorhome cockpit windows & leaks bkahler General Motorhome Topics 11 02-25-2017 07:13 AM
Cockpit windows needed Jetstreamer Classic Motorhomes 22 06-10-2014 11:43 PM
cockpit heat ALANSD Mechanics Corner - Engines, Transmission & More... 15 04-25-2012 03:28 PM
cockpit windows fuzzy channel replacement wb13798 General Motorhome Topics 33 01-10-2010 10:49 AM
cockpit windows chiropup General Motorhome Topics 7 01-19-2004 11:26 AM
