Old 06-16-2016, 01:00 PM   #1
1994 31' Legacy 30
Lakewood , Colorado
LY 94 30 Marquis 5000 air filter housing
Ordered filters for my LY 30 marquis 5000 genset only to discover the Onan 140-1894 air cleaner housing was gone. Dealer who sold it too me as is told me to check the genset..for good reason. I have not been able to locate a replacement housing new or used anywhere apparently discontinued by Onan. Anyone have any suggestions for anchoring the air filter?
runter is offline   Reply With Quote
Old 06-16-2016, 10:41 PM   #2
Registered User
1996 30' Land Yacht
Benson , Arizona
I'd try a generator repair shop. I was in the local Onan dealer a couple weeks ago picking up an extended oil filter, plugs, air cleaner, and fuel filter for out Marquis 5000. They had a nice looking (one of those "beauty is in the eye of the beholder" kinda things...) boneyard out back.
If you can't find a source, let me know and I can swing by in the next couple weeks.
pago cruiser is offline   Reply With Quote
Old 06-18-2016, 12:44 PM   #3
1994 31' Legacy 30
Lakewood , Colorado
Found solution
The missing air filter cover was an elaborate one with lever to switch air intake from heated to cool. Since I only use the gen set in warm weather I went to McGuckin's Hardware in Boulder, probably the best hardware store in the country, and found a large washer that covered the filter end than added a smaller one for the 14-20 3 1/2" bolt. I chose one that was 4 1/2" and they swaged a knob on one end so I can replace the filter by hand.
Thanks for your offer to help. That heat down there must be getting impossible for you to offer to drive all the way to Denver area to assist, but thanks anyway.
Randy
Old 06-18-2016, 07:36 PM   #4
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
I have 1 major problem w/ McGuckins. I go in & hate to leave!
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Old 06-19-2016, 06:30 PM   #5
Registered User
1996 30' Land Yacht
Benson , Arizona
Funny guy..
Glad you figured out a solution.
It has been hot. How hot you ask?
So hot...
Its been so hot... the lowest temp on our oven is 130F...
So we turned it on and climbed in...
That said, have you figured out a way to change the rear spark plug without pulling/dropping the Genset?
Looks like a royal pita...
Old 06-20-2016, 10:21 AM   #6
1994 31' Legacy 30
Lakewood , Colorado
Changing rear spark plug
Changing the plugs is my next project and was going to be my next question. Without an owners manual and no instructions how to do this I am looking for the same answer. Surely the genset shouldn't have to be dropped to change a plug. Anyone have the solution?
Old 06-20-2016, 05:55 PM   #7
1994 31' Legacy 30
Lakewood , Colorado
Smile Changing rear spark plug
Found this post in http://www.irv2.com/forums/f84/repla...lug-96238.html
Depending on the model, especially the 4000, they tip down. Place a floor jack or a scissor jack from your car under the outer edge. There are two bolts that release the generator and let the outer edge drop down. It will give you access to the rear plug.
Will paper air filter change dynamics of engine with K&N filter? Astrodokk Mechanics Corner - Engines, Transmission & More... 23 09-05-2016 02:24 PM
Onan Marquis 5000 Generator problems cruiser1 Land Yacht/Legacy Motorhomes 21 04-22-2015 04:33 PM
Repair water filter housing? dolphin44 General Repair Forum 8 04-14-2014 07:55 PM
(2)...airsteam outside marquis signs..read.."international airstream" eBay Watch Airstreams on eBay 0 07-01-2012 03:20 PM
towing with a Grand Marquis Chas Our Community 14 01-28-2003 12:54 PM
