Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Land Yacht/Legacy Motorhomes
Old 12-29-2007, 06:20 PM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Location of Tranfer Box in 2003 LY
Can someone with a 2003 AS Land Yatch tell me where the switch box is located? It's not in the rear trunk area where I thought it should be. Thank you.
spat61 is offline   Reply With Quote
Old 01-05-2008, 08:12 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I looked through the 360XL manual (downloaded a copy), and there is no mention of the ATS switches. My guess is that it will be near the shore power. On my '94LY the shore power is at the left rear corner, and the ATS switches are located quite high up under the rear panel that swings up behind the radiator (mine is a diesel pusher). At the same time, the main breaker panel for 115volts is located inside the coach, just beside the bed roughly in line with the ATS switches.
Why are you looking for the ATS switches? Is it an issue with a failed component within the ATS switch (I had a burned out time-delay relay in mine which I subsequently sourced, purchased and swapped out the defective one).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Only choice location--TV? Kistler Generators & Solar Power 7 06-11-2007 08:58 AM
Bathroom location? 5003 Off Topic Forum 3 05-14-2006 11:49 AM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
AC location - 1966 Forrest 1965 - 1969 Globetrotter 0 04-17-2004 09:07 PM
Airsteam Recalls 2000-2003 Land Yacht -- 08/07/2003 jpurdy Our Community 0 08-14-2003 07:19 PM
