Old 09-23-2009, 01:00 PM   #1
Safari 62's Avatar
1962 22' Safari
2014 30' Flying Cloud
Grayling , Michigan
Land Yacht purchased with property
Hi, I joined last night and have looked all over today to try to find out what I bought! I know it is a Land Yacht Safari. The first line of digits are 22TS or 22T5 S0732. The second line is 6201. Made in California, I believe.Click image for larger version
Safari 62 is offline   Reply With Quote
Old 09-23-2009, 01:08 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us. You've found the right place for all things Airstream.
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 09-23-2009, 01:15 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Looks like it's a CA built 1962 Safari...congratulations!
Shari
Old 09-23-2009, 01:49 PM   #4
Safari 62's Avatar
1962 22' Safari
Grayling , Michigan
The brake lights in the back are wider than the window and it doesn't have 3 lights in the back across the top...just one on either side.
Old 09-23-2009, 02:11 PM   #5
Safari 62's Avatar
1962 22' Safari
Grayling , Michigan
I think you may be correct. It is theclosets one I have seen. Thank you...I'll have to change my ID to Safari62...haha. So excited.
Old 09-23-2009, 02:20 PM   #6
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
Is that really a Red Pine Tree in the picture in Belleville or is this a picture taken up North ??
Rollerboy is offline   Reply With Quote
Old 09-23-2009, 02:23 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
It definitely isn't a '65...it has 7 panels whereas a '65 has 5. '63 was the last year for 7 panels.
The marker lights above the windows are a CA vs OH thing...I have noticed the OH trailers from the early 60's have the marker lights whereas the CA trailers do not.
The wide spread tail lights might be because your trailer originally came with a spare tire mounted to the back bumper. I know they did that in the early 60's as an option...it has since been realized that it caused undue stress on the frame and most will agree it isn't a good idea.
Shari
Old 09-23-2009, 05:39 PM   #8
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Welcome to the forums! You'll find many helpful folks and great info here.
You can do that if you want to. Just use the link below and request a name change. I'm sure they will oblige if it's not already taken.
http://www.airforums.com/forums/sendmessage.php
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 09-23-2009, 06:23 PM   #9
airstreamjudy's Avatar
1968 24' Tradewind
Largo , Florida
Welcome, in searching use the google search - you'll get more results related to your questions. Good luck with your new baby.
Judy
JudyW
airstreamjudy is offline   Reply With Quote
Old 09-24-2009, 05:08 AM   #10
Safari 62's Avatar
1962 22' Safari
Grayling , Michigan
The red pine is from up north, not Belleville. Thanks to all for the helpful info, muchly appreciated. I better not change by ID though until I find the exact year.
Old 09-24-2009, 08:10 AM   #11
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
The 6201 tells you it was off the assembly line in January of 1962 so go right ahead and change your ID. The rest of your serial number (22TS S0732) indicates a 22 foot with twin beds made in Santa Fe Springs, CA. The remainder of your serial number is the sequential number of your trailer off the assembly line.
Welcome aboard, since its a Land Yacht. As previously mentioned, use the search feature for your questions, or ask here, and post lots of pictures. We love pictures.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 09-24-2009, 08:10 AM   #12
Rhonda's Avatar
1956 26' Cruiser Overlander
1970 23' Safari
Lambertville , Michigan
That Airstream would make me want to buy the property!
Rhonda is offline   Reply With Quote
Old 09-24-2009, 08:14 AM   #13
Maryw164's Avatar
1972 31' Sovereign
I found this post on a "help with VIN #" thread:
http://www.airforums.com/forums/740691-post2.html
It outlines how to decode a VIN #
Hope it helps.
Mary
Happy Trailering !
Old 09-24-2009, 09:09 AM   #14
CanoeStream's Avatar
St. Cloud , Minnesota
Mary, the proper link for pre-1980 VINs (and more) can be found at http://www.airforums.com/forums/f238...tml#post445050. But the pre-1980 pdf has a bigger problem -- it doesn't show the difference between Ohio & California VINs. So Safari65 can't count on any pdf.
Mary, you got it right that he is ready to use your http://www.airforums.com/forums/sendmessage.php link to contact tech support for that name change!
Safari65 - I fully believe that InsideOut and flyfshr are giving you the correct recommendation. The broader resource that Shari linked in post 3 is Steve Dial's web page -- Vintage Airstream Photo Archives -- look there for examples of other year VINs. More to the point -- look at the VIN in the link Shari gave you (emphasis on the red underlined area):
Name:	62 Safari VIN.jpg
Your VIN of 22TS S0732 gives a sequential production number of 0732 - which falls between the 0630 and 0875 given in the attached image. And there are no similar 22TS S0732 VINs on Steve Dial's page. Does this mean 875 minus 630 = 145 Safaris produced at the California plant that year? The parenthetical remark in the image suggests 145 might be the number for both California Safaris & Flying Clouds together -- but others might give that a better guess.
So go ahead and send your message -- you've got a 62. (what does the title call it anyway?) But I checked the database -- we've already got members with usernames 62Safari and Safari62. Available are either 62 Safari or Safari 62. Okay?
5 meter Langford Nahanni
Suggestions for Property storage kitchenclose Cleaning, Stripping & Polishing 2 03-30-2009 10:37 AM
No Land Yacht? Ganaraska Airstream Trailer Forums 3 03-07-2009 04:20 PM
Who has vacation property? Stefrobrts Off Topic Forum 32 05-21-2008 06:15 PM
RV/Recreational Property bhayden Off Topic Forum 4 05-22-2007 08:36 AM
Land Yacht turning into a water Yacht Jacob80 Sinks, Showers & Toilets 10 04-08-2007 08:48 PM
