Old 02-16-2019, 05:18 PM   #1
Madisonville , Tennessee
Land Yacht Leveling
I'm looking at a 2005 Land Yacht Motor Home. The seller doesn't know what kind of leveling system but does know it doesn't work. Can someone tell me what manufacturer Airstream used in 2005 for leveling systems? HWH? Big Foot?
Many thanks
jimandtere is offline   Reply With Quote
Old 02-16-2019, 07:25 PM   #2
2004 19' International CCD
Longmont , Colorado
A quick look at the manual on the Airstream webpage indicates it was potentially just an option... so the first question may be, does it have a levelling system.
A google search for "2005 airstream land yacht leveling system" returned several pictures and listings of 2005 models for sale that show the control panel and system being a "Power Gear" controller from Lippert.
Hopefully that helps a bit, or someone with an actual 2005 chimes in. There are also a few posts for land yachts in the late 90's through early 00's discussing Power Gear leveling systems. This sub-forum may worth a look or search:
http://www.airforums.com/forums/f313...em-142295.html
Good luck!
cstein is offline   Reply With Quote
Old 02-17-2019, 07:34 AM   #3
Thanks. From what I've read, they did use Power Gear. I've done a fair amount of research on them and Power Gear has lots of problems. HWH is the best system out there and I do believe it would be better in the long run to let them take the Power Gear stuff off and install the HWH system. $4K Can't understand why a class act like Airstream would use a second rate leveling system. Oh well.
Old 02-23-2019, 12:45 PM   #4
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepardstown , West Virginia
Images: 14
Mine has Power Gear leveling and considering its age, no problem other than my two front levels were leaking. They were taken to a farm equipment shop that deals with hydrolics regularly and rebuilt. Cost $150 total.
Otherwise only issue is when its very cold they take longer to extend.
Mike1997 is offline   Reply With Quote
Air stream 27 land yacht travel trailer rv sair stream 27 land yacht travel trailer r eBay Watch Airstreams on eBay 0 08-06-2011 10:10 AM
Airstream Land Yacht Diesel Repo Slide out Wash/dryer SAirstream Land Yacht Diesel R eBay Watch Airstreams on eBay 0 08-04-2011 07:10 PM
2002 airstream land yacht xc365 s2002 airstream land yacht xc365 eBay Watch Airstreams on eBay 0 07-22-2011 09:10 AM
74 Airstream Overlander Land Yacht F131 Land Yacht eBay Watch Airstreams on eBay 0 04-02-2010 01:50 PM
Leveling Jack Problem 1998 30' Land Yacht gcox2204 Jacks, Stabilizers, Lifting and Leveling 0 09-01-2009 08:11 PM
