Old 05-14-2015, 06:55 PM   #1
Paul Dobbin's Avatar
1994 35' Land Yacht Diesel
Franklin NC , North Carolina
Land Yacht fresh water leak
Where the city water comes into the coach, it passes thru what looks like a pressure regulator (Brass thing with an adjustment screw on top)
Problem is that pressure regulator leaks when using the pump for water pressure instead of the city water.
Seems that would be back pressure on the thing instead of pressure in the flow direction it was designed for.
I know there is some experience with this problem out there. Any ideas?
Since we never use city water and always run off the pump, may I just eliminate the leaky part?
Paul
"The Roadhouse" our Land Yachts name
Paul Dobbin is offline   Reply With Quote
Old 05-15-2015, 09:34 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Why not just replace it PAUL?
Take a picture of it and it should be available at any hardware or RV outlet?
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 05-15-2015, 10:12 AM   #3
1974 Argosy 20
Kooskia , Idaho
Probably the standard Watts pressure regulator AS has used for many years. There is also a check valve between it and the outside city water inlet. The regulator has probably cracked somewhere, thus the leak. I think that Home Depot carries them, or something similar. If you never use the city input you certainly could remove it. Just don't eliminate the check valve, or else cap the city water input off.
The next owner might curse you for eliminating it though.
Old 05-16-2015, 05:03 PM   #4
Thanks guys, I guess I'll have to look again for the shut off. Then replace the Watts pressure regulator you cited. The AS Forum works again.
Paul
Paul
Old 05-17-2015, 12:23 PM   #5
1977 31' Sovereign
Lynnwood , Washington
Watts water pressure regulator =
LF223, LF223S Lead Free* High Capacity Water Pressure Reducing Valves, Water Pressure Reducing Valves - Super Capacity, Water Safety & Flow Control - Watts
I replaced mine a number of years ago with a Watts Model 70. I think it must be discontinued. I don't see it on the Watts web site.
BTW - I reconfigured the plumbing to accommodate a water pressure gauge. I can now adjust water pressure to my liking: 45 PSI @ pressure relief valve; 50 PSI @ water pressure regulator.
Tom
TomKirk is offline   Reply With Quote
Old 05-17-2015, 03:30 PM   #6
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Why wouldn't a check valve placed between your pump and pressure regilator not solve the problem?
Fact is, unless I am mistaken, there should be one.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 05-17-2015, 07:58 PM   #7
Thanks guys, I'm taking it with me tomorrow to get a new one. Yes there is what I thought was the in line pressure regulator between the city water inlets and this, guess it's actually a check valve.
With your advice I'm taking it all to the plumbing supply less than two miles away.
Great Forum
Paul
Old 08-15-2015, 05:28 AM   #8
Soon after my last post I replaced both the check valve and pressure regulator and now can use city water or the pump, NO LEAKS.
Thanks Airstream Forum!
Paul
Old 01-25-2016, 12:10 AM   #9
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
My 97 LY diesel pusher just started leaking at the same point. This winter I have used the pump and fresh water tank vs city connection. After the cold in Montana it now leaks when in use. Sounds like I need to do the same and replace the check valve and pressure regulator.
Mike1997 is offline   Reply With Quote
Old 01-25-2016, 07:47 AM   #10
1956 22' Safari
Images: 11
Mike, check Amazon for the regulator. For a while they were selling them MUCH cheaper than RV suppliers. Just be sure on the pressure value.
steelbird312
1989 29' Excella
Old 01-26-2016, 11:33 PM   #11
1974 Argosy 20
Kooskia , Idaho
BTW, Home Depot generally has pressure regulators with shark bit fittings on each side which can make replacement much easier. I think they are Watts too. Around $50 as I recall, but might be higher. I don't know if they have a shark bite check valve.
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
'72 Tradewinds Land Yacht--fresh water inlet? nadiar79 Plumbing - Systems & Fixtures 16 08-07-2016 01:13 AM
1975 Tradewind Land Yacht- Location of fresh water drain valve dirtman 1970-79 Tradewind 1 11-13-2013 03:30 PM
1972 25ft, land yacht fresh water pluming replacement wisdumb Fresh Water Systems 1 09-18-2011 10:22 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
