Old 03-16-2016, 06:50 PM   #1
baldwinh's Avatar
2002 36' Land Yacht XC Diesel 300 hp w/2slides
LIVINGSTON , TX
Know What This Switch Does?
Does anyone have an idea of what this switch function is on my '03 Land Yacht XC Motor Home? The on-off rocker switch between the generator hour meter and the solar charge indicator. It's secured with brass flat head wood screws instead of black round head screws like the others. It looks like it may have been added after production.
I can't find any reference to it in any of the documentation.
Thank you,
Name:	2015-12-09 08.41.29.jpg
Herb Baldwin
2002 Airstream Land Yacht 36 DP MH'
2006 Saturn Vue
herbsells@gmail.com
baldwinh is offline   Reply With Quote
Old 03-21-2016, 11:09 PM   #2
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
I could not enlarge the photo but my guess is, its either a water heater switch or possible a kill switch for the coach batteries. Usually Airstream had 2 switches for the water heater, one in bathroom and other on the control panel. My batter kill switch is near the side door but it makes more sense for it to be on the control panel.
Check and see if either of these might be the answer.
Mike1997 is offline   Reply With Quote
Old 03-23-2016, 04:46 AM   #3
baldwinh's Avatar
LIVINGSTON , TX
Smile Thanks Mike
Mike, I'm guessing you're right about the water heater. I pulled the switch and found that the wires to it are heavy gauge, like #14 solid copper home electric "romex" wiring, so I'm guessing it's the electric heat cutoff switch, just find it odd that it's not labled. In the bathroom there are two switches. One is a small 12v switch with red indicator light that I think feeds the 12v circuit to the water heater for LP use. The other is a typical home-type light switch labeled "water heater" for the 110v element.
The coach battery disconnect switch just inside the front entry door activates-deactivates a relay in the rear basement battery compartment turning off all 12v feed to the coach.
Thanks for your input.
Herb Baldwin
2006 Saturn Vue
herbsells@gmail.com
Old 03-24-2016, 06:01 PM   #4
loreepeter's Avatar
2004 30' Land Yacht Gas 30
, OH
Water heaters have used a relay mounted at the rear of the heater. The relay connects the heating element to the lead from the load center. Remote switch (s) open/close the relay. The different screws were added ... ???
Atwood (ours). 11 years. .... Uses the relay. Replaced after 7 years... No big deal, easy fix.
gonagn
loreepeter is offline   Reply With Quote
Old 04-01-2016, 04:55 AM   #5
baldwinh's Avatar
LIVINGSTON , TX
Thanks folks. Turns out it indeed is the switch that turns on and off the water heater in the electric mode. The switch for the lp mode (switching the 12 volt circuit) is located (and labled) in the bathroom under the vanity mirror, but this switch located on the control panel in the hallway controls the 110v electric circuit
Herb Baldwin
2006 Saturn Vue
herbsells@gmail.com
I know I should know this blucloud Towing, Tow Vehicles & Hitches 10 09-13-2015 07:47 AM
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 10:45 PM
'70 31 ft Sovereign International (does anyone know what this switch controls?) travalota Lights - Interior & Exterior 4 09-27-2011 06:51 PM
Dover, DE Does anyone know? markjoandall Other Rallies & Events 1 04-30-2003 01:45 PM
Does anyone know #16019? Pahaska Our Community 15 06-30-2002 04:25 PM
